You are quite right about the time of use charge being high 1400-2000. I have a power wall 2 that gets me around that. @Vostok started this thread Fun with Powerwall 2 stats... that goes through some of this stuff in more detailAll good info. Interestingly I am with Powershop at three properties, none of which are on the EV plan. While investigating the deal I see these EV plans involve time of use charges that range from the super cheap tarrif 0000-0400 that may only be 9c depending on which state you live in, to over 40c at peak which is very high (42 in Vic). Whereas my existing Powershop plan is flat rate at 28c 24/7.
So unless one is routinely charging the car every night, to take advantage of the EV tarrif, the higher peak rate for power consumption in the late afternoon and evening could ameliorate quite a bit of the EV gains. Food for thought.
