Could I use this 30amp dryer socket to charge a Tesla?
First problem is that is a 10-30, old-style, dryer outlet, not a 14-30.
The 14-30 has 4 pins, 2 hots, neutral, and ground. The 10-30 has 3 pins, 2 hots, a neutral, and no ground.
See "NEMA 20 connector - Wikipedia" and "NEMA 14 connector - Wikipedia" for details.
So why wouldn't that work with the Tesla 10-30 adapter?
It certainly should. Buy one, and give it a try... Tesla Accessories and Charging Adapters NEMA 10-30
I have one of these 10-30 adaptors and it works well NEMA 14-50R to 10-30P Adapter
The thinner more flexible cable is useful in situations where the plug is placed such that you need the cable to make a sharp turn coming off the plug.
Set the amperage level in the car to less than 30A.
Note that using this adapter is going from the dryer plug, a 30A circuit to a Tesla 14-50 plug, which is a 50A circuit, so the car won't know the right level of amps. Set it to 24A max if you're going to use this, so you don't try to overdraw from that outlet.]
Aren't you supposed to set the amperage to 24A in that case?
This^^ ...if I can just run 15' 10-30 extension cord, I'm golden. :smile:A better approach is to use Tesla's 10-30 adapter wherever possible, even if it means a small 10-30 extension cord rather than that adapter
This^^ ...if I can just run a 15' 10-30 extension cord, I'm golden. :smile:
I own a 125 year old home in California. All the electrical was put in as an after. There are still old ceramic insolators in the basement. The home was re-wired some time in the 40's-50's. Service panel is maxed out. Any re-wire project would just open up a can-o-worms I'm not ready to deal with. a short 10-30 extension cord puts me in the Tesla game...Just as a note, Tesla expressly prohibits the use of extension cords in its documentation, and the NEC requires you follow manufacturer's instructions - so technically, you're violating the code. You get to decide whether that's a risk you want to take.
I think by "problem", Cottonwood was referring to the fact that it was really a 10-30 outlet, not a 14-30 outlet (as the OP put in the thread title).
