TomB985
At lower speeds, it is more "microadjusting", but on expressways, it definitely feels fatiguing after 15 mins of driving (now I basically have to use autopilot on expressways). From talking with tsportline and the tire shop, both think it has nothing to do with alignment, but rather how much softer the rubber is on the X-Ice Snows, even compared to other winter tires.
Next time I may go for a Blizzak performance winter tire, as my wife's van has a set of Blizzaks, and I've never noticed any "wandering" or feeling unstable with those tires (then again - they are runflats, so stiffer sidewalls).
You may find better stability after they accumulate a little wear.
Also - I was suspicious of the lug nut torque that the tire shop did when they installed my winter tires, and when I checked them, all were between 90-100 ft/lbs... I torqued all up to ~129. I am 99% sure it is only psychological, but it feels more stable since.
It’s always nice to check, but I’m 100% sure it’s psychological. There is either movement or there isn’t…and any movement wouldn’t last very long before the wheel came off. Good call checking, but this doesn’t have anything to do with your wandering issue.
