Looks great! Would you mind posting a photo from the side as well?Here’s my winter setup with OEM Tesla Mode 3 rims on 2022 MYLR with Michelin X-Ice SUV - 235/55/18
Also, which license plate bracket are you running in the front?
Doesn't clear performance break calipers, sorry.Any idea if the new 750kg Model 3 Rims will fit a 2022 MYP?
Thanks!Looks great! Would you mind posting a photo from the side as well?
Thanks!
It’s a snap plate I bought off Amazon, so far, so good.
Here’s a photo from the side
I really wanted to do this setup as well but could find any gen2 Aero wheels locally.
I lucked into a set of aero wheels off a '22 M3 locally
Did ever get the 245/55r18 if so any issues with rubbing I'm thinking doing the same on my 2022 model Y LR with 18x8.5 wheels . Thanks for your time.Sorry to resurrect this thread, but I have some questions. First, those who have made this move over to 18" aero, have you been happy with it? Second, from what I see most of the 18" tires that I'm seeing are "V" speed rated instead of "W", will this cause issues? Lastly, I'm trying to figure out which sizes will clear the knuckle that's next to the tire. I've seen 235/55R18 and 255/55R18. I'm thinking of going with 245/55R18 to get slightly narrower for more efficiency but also some more sidewall. DiscountTire's website suggest 245/50R18 for an optional size, so I'm trying to see what I'm missing if anything as there aren't nearly as many of those. Any help/insight would be appreciated!
245/60 fits so I think you’ll be fine.Did ever get the 245/55r18 if so any issues with rubbing I'm thinking doing the same on my 2022 model Y LR with 18x8.5 wheels . Thanks for your time.
No. Yes.Maybe a dumb q but does the different offset matter and can the same lug nuts be used?
Thank you to everyone for the info in this thread.This has been such an informative thread and has really helped a lot!
I was able to snag a great deal on some 750kg rated aero wheels (Part #1044261-00-A) with Tesla TPMS sensors included. I plan on getting Blizzak DMV-2 100T or 103T and make this my winter tire set. The tires did really well on my old car this epic winter in Tahoe.
I have been bouncing around this and other threads, in search of whether I am missing washers for the TPMS sensors but cannot find it (I was able to get the torque spec).
Does anyone know if the Bluetooth sensors require washers for install? Mine did not come with any.
Wrong size tire.Thank you to everyone for the info in this thread.
First time tesla owner (pickup soon of MYLR) and the 19" winter tire package is sold out on tesla's site.
What about purchasing the M3 winter tire package, which is currently available for $1900 on tesla's site, for the MYLR? The service center may be reluctant to install but I could do that at home at a later time.
Model 3 18" Aero Wheel and Winter Tire Package
Model 3 18” Aero Wheel and Winter Tire Package provides maximum safety and grip when driving in wet or dry conditions and on icy or snow-covered roads. The winter package guarantees a high level of traction, stability, and braking efficiency under 45°F. Includes: 4x 18X8.5J Aero Wheels 4x...shop.tesla.com
thank you. I will look for a used set of Aero 18s locally and then get the 235/55R18 XL tires with it for winter uses. Appreciate it.for the Model Y 18" Aeros from the model 3 (works quite well with 235/55R18 XL)
note that tire size is for the Model Y and is NOT the tire size from a Model 3.
If you buy the winter tire package for a model 3 you would then have to buy 4 more tires in the right size and swap them and then you would have 4 new tires to sell that don't fit your model Y.
Even if you buy Model 3 pulls (used wheels) you'd end up with 4 tires to get rid of in many cases.
It's just a matter of cost and convenience.
do you have results with this setup to share?This info is amazing. I found a local set of 2022 Model 3 18in wheels (750kg rated) that I plan to use for my winter set on my MYLR. The only other scenario of max loading I could think was ski season with the roof box full of skis and 3 kids in the back. But this still doesn't seem like it would any worse than scenario H. That would give a wide margin if you added 110lbs per axle.
For tires I'm leaning towards 235/55/18 Blizzak DM-V2 rated at 100T (800kg and 118mph). These should land at 0.7% larger diameter than the stock setup. Or I can go with the X-ICE SNOW SUV which are XL and 104 rated. They are a bit more expensive though. Do I really need the 104 rating (900kg) if the wheels themselves are only rated to 750kg?
Any issues anyone can see?
Also with the BLE TPMS self-calibrate and work? Will it be a problem to store my stock 19" Gemini's in the garage next to the car for the winter?
