TT97
Pilot S4 is only for the 20" model. Not the 18".
From P. 128 of the Owner's Manual:
As I stated, "the Owner’s Manual also references Michelin Pilot Sport 4 as OEM for the 18” but not holding my breath for those."
Funny the two 19 inch Michelin’s mxm4 are 50 dollars per tire cheaper then the 18 inch at tire rack.
Wheel diameter is measured from where the tire bead sits, not from the outer lip of the wheel.Just today I took a rim to rim diameter measure of the wheel and the reading was 19.5 inches.
I am interested in this question. I put the Michelin PS4s on my BMW 328i and really like them. I was thinking of switching to the PS4s from day one on the Model 3 but I would like to hear if anyone has real-world experience and whether it's worth the swap cost.Well, since they are the same width, you are paying for an extra half inch of side wall [yes, it’s strange Tesla spec’d more expensive tires on the 18.]
I know it’s early in ownership, but has anyone put the Michelin PS4 on their 18”? Impressions?
What reasons did they give?By the way, I have info from the engineers at Tesla direct that they do not recommend 20" wheels for this model. Although they are now offering one, you need their upper control forearm links and they don't sell them alone. They approved my 19" setup of 245/40 and 275/35.
Just an FYI.
That is a new update. Mine only listed the MXM4's. They added the snow tire type as well.
The Manual is dated April 20th (although I think it was in the March version as well).
No reason given. Just that they did not recommend 20's. I didn't want the super thin lip and to have the blowouts like the 21" turbines on the Model S. I got the same width with a 19" and thicker sidewall.
I have Pirelli P Zeros now and actually would be thrilled with them lasting 20k . I drive less than 10,000 miles a year so end up replacing less often (also means it will be a while before I burn through the starter set). My current car is a 3-year lease coming due in two weeks and I have 25k miles on it.
Were they referring to 3rd party 20" or the Tesla ones as well? The Tesla's come with rear upper fore links.
Which P Zero? I am running the All Season Plus so I get best of both worlds and 50K mileage guarantee.
Couldn't agree more. I did not like the 19" square option at all and they weigh a lot. I didn't want the same issues as the MS with the 21" turbines and blowouts so going 20's wasn't even an option for me. The 19's do everything the 20's do and give me that peace of mind that I won't hit a pothole and blow out a tire or bend a rim. They cost double the factory option but people are banging my door down to get my old 18's as backups. Once I confirm the setup, they are gone! It's only been 2 weeks on this combo and they are working great. Just finalizing the lowering setup with Unplugged here in LA. It appears the new 2018 M3 has a different rear suspension setup than the 2017...hummmmm. So the springs actually lower the car MORE than originally engineered...work in progress. Car goes back Monday for engineering. Update you later on that one...
Hmm haven't yet heard about how the 2018 springs are lower.. I need to read up on this
P Zero Run Flat Summer Tires.
Would like to be able to order with 18" summer tires directly to save trouble switching and selling. All seasons are pointless in socal, switching to summer performance has made such a difference in the past on my s2000.
I would disagree. It totally depends on the use and how many miles you drive per year. If you put low miles on a car, then performance is fine but if you commute and drive a lot (I drive 20000+) per year, then the All Season are a much better deal since you get the 50000 mileage guarantee. The summer tires are usually 20,000-30,000 miles max, and if you have a staggered setup, it's 1/2 that amount. Unless you love spending over $1000 a year on tires, knock yourself out, but I want performance and mileage out of my setup. To each his own...
