of course it's safe; done properly.Is it safe to put smaller tires (ex: 18 inches) than 19 inches for a model Y?
I will add make sure your wheels carry the proper weight limitof course it's safe; done properly.
however, you have to pay attention to clearances.
the wheels have to clear the brake calipers and have the proper offsets to the tires clear the suspension bits and don't stick out of the wheel wells.
the tires have to be the proper diameter so as to clear the steering knuckles in the front, and proper width to clear the suspension bits.
there's plenty of info here on these threads.
That would have to include any stick-on wheel weights.the wheels have to clear the brake calipers
18" tires are technically bigger than 19". The outside diameter remains the same however the inside diameter is smaller resulting in a higher sidewall. There are more choices to be had in 18" sizes and in general they are also cheaper plus having more sidewall they give a slightly better ride compared to the 19s. No issues at all going from 19 to 18.Is it safe to put smaller tires (ex: 18 inches) than 19 inches for a model Y?
as example:...why would you want to?
You guys don't have a dealer in Toronto, Ontario, Canada do you?
We don't. We ship worldwide directly to your door!You guys don't have a dealer in Toronto, Ontario, Canada do you?
Thanks.
wheels won't make much difference, it's the tires, and even those aren't going to be hugely different.Has anyone compared efficiency of T Sportline rims vs Geminis?
So aerodynamics on the wheels don't expect much?wheels won't make much difference, it's the tires, and even those aren't going to be hugely different.
Buy tires that make sense for your need and fit your budget.
noSo aerodynamics on the wheels don't expect much?
minutiaeGemini caps make a difference on Apollo wheels. I can't recall the %, but their is a YouTube vid on it.
2-3% differential between wheel types.4-5%
