Tesla Model S bike collision test, tesla will not kill cyclists.
Tesla Model S owner tests Autopilot's ability to avoid hitting bikers [Video]
In 2021/22 and beyond, if Model 3/Y can achieve 300 mile range with 50 kWh battery due to 7% per year improvements in battery density,
50kWh is 50kWh as far as capacity goes. Hence I assume you must be claiming that the additional range will be due to lesser mass.
I think folks overestimate the effect of this amount of mass reduction on range. A compounded 7% increase over 5 years represents a cell mass reduction of 1/3rd. And even though that's only part of the overall pack mass, as not everything scales downward linearly, I'll still be conservative and say you can reduce the entire pack mass by 1/3rd.
My Model S 85kWh pack weighs something like 1200lbs. So I'm going to say a 50kWh Model 3 pack will weigh ~700 lbs.
Shave 1/3rd of that weight off, and you save 233 lbs. I seriously doubt a mass reduction of 233 lbs is going to allow a 50kW to go 300 miles. That's a power consumption of only 167Wh/mi. Especially when many are hoping a Model 3 with a 60kW pack will make ~240 miles, which is 250Wh/mi. Even 275 miles on a 60kW pack is 218Wh/mi.
You are expecting a 30-50% improvement in power efficiency with that little of a mass reduction. Ain't gonna happen, IMO.
I can tell you that adding or removing 233lbs worth of passengers and cargo on my Model S makes almost no difference in range... especially at highway speed where aero forces dominate.
I'm not sure how competitive this will be vs. Tesla's all-electric fully autonomous fleet 2018+
May not be long term competitive but is a good explanation for the dip today (short term)
20 million cumulative by 2025 is just starting at about 390k delivered in 2018 and growing 50% annually thereafter. I don't know why you'd think that growth would drop from 50% in 2025 to GDP levels, ~3%, in just one year. I think Tesla will have much more growth in it well into 2030s.I haven't received many responses to this. Any thoughts, anyone?
FWIW, my DCF assumes 20+ million cars at end-2025 on Tesla Network, growing at the global GDP growth rate thereafter.
This could mean many tens of billions of dollars in annual gross profit from Tesla Network by 2025.
This will probably prove conservative as Tesla will likely have built its "8-12 Gigafactories" by then, and will continue to grow faster than GDP.
We don't know what the Model 3 range with 60 kWh pack will be. I think it may be higher than the ~240 miles you noted that many are hoping... Please check this out and let me know your thoughts:
New Model 3 photos surface, pointing to 300+ mile range and interior details
My guess is that this model 3 has the 75 kWh pack. It is extremely likely that the initial model 3's will have the large pack.We don't know what the Model 3 range with 60 kWh pack will be. I think it may be higher than the ~240 miles you noted that many are hoping... Please check this out and let me know your thoughts:
This trajectory also assumes that Tesla needs enough battery capacity for 6.7 million vehicles in 2025. So vehicle production capacity needs be at 6.7 million vehicles. At 100kWh per vehicle (conservative), Tesla will also need 670 GWh of battery production capacity. We don't know what the average capacity of a Gigafactory will be, so I am content to simple express capacity needs in units of veh/yr and GWh/yr. But certainly this could involve some 8 to 12 Gigafactory campuses.
Anybody know why the Fremont plant is not called a Gigafactory? I'd like to think of if as Gigafactory 0. (Programmers may have issues with this depending on their preferred language.)
I agree. 75 kWh and ~300 miles is what's been expected for many months now.My guess is that this model 3 has the 75 kWh pack. It is extremely likely that the initial model 3's will have the large pack.
Because they dont make any Gigawatts in Fremont. GF2 is supposed to pumping out panels and solar roof tiles at a rate of multiple Gigawatts per year. If battery densities continue to rise, do we think they will be building Terafactories at some point with combined Battery and Solar output of 1000GW/Y. Thats a lot of cars and roof tiles. 20% of the new roof market (20% of 5M/Y) would be 5GW with an average sized 5KW system so probably no Terafactories required. You would want to spread out the Gigafactories to shorten the supply chain and get closer to where the product is going to be used.
And I can understand the decision to hold off on AWD, performance, etc to keep things simple. But starting with the small pack would mean *adding* complexity for less initial demand and revenue. It makes no sense.
