ValueAnalyst
Closed
Even if that's the case, I believe folks are overly optimistic about range gains. (And I actually think some folks think that 2170 cell based kWh are somehow better than 18650 cell kWh... but a kWh, is a kWh, but that's a separate discussion)
Let's look at it a different way:
A Model 3 is about 80% the size of a Model S. A Model S RWD weighs about 4,700lbs. Likely the Model 3 will have less options, reducing some weight. But it also will incorporate more steel rather than aluminum, increasing weight. Let's say those cancel out and use 80% as our mass target, that's 3,760lbs.
A weight savings of 233lbs is only a 6% decrees in mass. Yet the idea that you can reduce the battery capacity by 17% (from 60kWh to 50kWh), and expect to go the same distance doesn't makes sense.
Again this is particularly because the mass comes in to play primarily during acceleration/deceleration. It has some impact on rolling resistance. It has zero impact on aerodynamic forces.
As such, I'd expect that 6% mass reduction to have perhaps maybe 1-2% actual range impact. Not nearly enough to shave 10kWh off the battery and expect to go the same distance.
My projection relies mostly on battery energy density improvement year-after-year that approximate 5-8% per year rather than weight reduction.
https://www.quora.com/Is-it-true-that-battery-energy-density-improves-5-8-per-year
This was the primary reason why I said Tesla could maybe use a 50 kWh battery for Model 3/Y by 2020, while keeping range at ~250-300.
I did not see energy density improvement anywhere in your calculation. What am I missing?
