Wish we could always ask the same person to get the right answer![]()
Even If it is the right person, you'll not get the right answer *all* the time, but you chances to be right more than wrong will improve...
Looks suspiciously like algebracadabra!At MIT in the fifties in addition to Murphy's Law of Experimentation which is well known, we were taught his law of analysis too: the right answer, divided by the wrong answer, and that multiplied by the wrong answer gives you the right answer. Just trying to be helpful.
Unless the wrong answer is equal to 0... Wich would imply that Murphy can explain why, sometimes, tsla bears are successfull by making a good answer disapearing into non-existent and then resulting in 0.At MIT in the fifties in addition to Murphy's Law of Experimentation which is well known, we were taught his law of analysis too: the right answer, divided by the wrong answer, and that multiplied by the wrong answer gives you the right answer. Just trying to be helpful.
u
It can also be used to respond to the question of how much model 3 are produced this week regarding tsla long term. In that case, whatever wrong answer is equal to 1 ; implying that the good answer is equal to wrong answer and thus equal : does not matter.
okay here is the deal EvermanI’m in as much as I can, but I’m looking to convert some core shares in my IRA into ITM LEAPs at a 3:1 ratio, targeting a delta of ~ 0.80.
Question TT: how do you think about when the right time is to make a move like that, near the upper band, lower band or it doesn’t matter, and why?
All in on either Jan18 or April2018 calls? January might be overkill but you are so confident...View attachment 253401 FYI Everman
See the hollow red candle today
This stock is going to $546 to $557 over the next 3 months or so that is by early January 2018
I've placed my bets accordingly
30% January 2018 and 70% January 2019All in on either Jan18 or April2018 calls? January might be overkill but you are so confident...
How were you not tempted to sell the Jan18 500Cs during the last rise to 380? Forget my last avatar recommendation. I have a new one for you. It's simple, just like your investment strategy.30% January 2018 and 70% January 2019
Almost all of them are in the money already and highly profitable or OTM but already doubled or tripled
The only call in loss is January 2018 $500 which is such a minor position that it's not even worth mentioning but I do mention it because I expect it too to move up very nicely in short order
I originally plunked $0.375 in all my calls and it's now well over $1 and was well over $1.4 back in June
I suspect it'll go much much higher from here
That's why I'm buying common like crazy because once I liquidate my calls almost all with long term capital gains I'll automatically convert it all to common by reducing my huge margin fractionally
Someone ducked out of a ~3 million share short position today? Whose the lucky loser, and how much did they lose?
Scale added.Is that picture to scale? Cause if blown up then mouse nuts, if shrunk then elephant nuts, if to scale...peas.
Apparently Siri has a response to this one (what is 0 divided by 0):
See what happens when you ask Siri 'what's zero divided by zero?'
Apparently Siri doesn't know calculus. The solution to every differential calculus problem involves dividing zero by zero.
