2018.28.1
Discussion in 'Model 3' started by Zaxxon, Aug 6, 2018.
  1. 9erDog
    9erDog Member
    Cypress, CA
    I am on the phone with Tesla and they are working on it. Puzzling to them as well as the car continuously cycles between charging for a short time to charging complete. Tried scroll wheel and touchscreen reboot with no change. Even changed charging stations (regular 1772) with no change.
    They have not been able to figure it out and are escalating the issue as they had not heard this one before.
  2. Zaxxon
    Zaxxon Supporting Member
    Colorado
    2018.28.2 just started hitting.
  3. miltymoots
    miltymoots Member
    San Diego, CA
    Just received 2018.28.2
    FD48EEF6-CE34-48DD-8585-0FB5820D2BFF.jpeg 9CB3537C-A2FA-4E14-B8E3-42200B403FBC.jpeg
  4. miltymoots
    miltymoots Member
    San Diego, CA
    2018.28.2 is already out. Just got it
  5. btews
    btews Member
    Urbana, MD
    I noticed this after going to 26.3...but thought it was just related to the car going to sleep (changed the power saver settings in TeslaFi to minimize vampire drain around the same time as getting 26.3). It's pretty annoying to have to unlock the car first, so I hope 28.1 really fixes this (I'm still on 26.3).
  6. PoitNarf
    PoitNarf My dog's breath smells like dog food
    NJ
    Well that was quick! Just 2 days after 2018.28.1 started rolling out.
  7. Snowstorm
    Snowstorm Active Member
    Ontario Canada
    Probably a bug fix for 28.1
  8. harcocjh
    harcocjh Member
    Chicago, IL
    I was thinking this today after getting it too! But I wasn't sure if it was just in my head. My battery was also low (about 30%) so tomorrow with a full battery will be the real test. If true it may just be that they adjusted the acceleration curve so the lower end has a bit more juice.
  9. smartypnz
    smartypnz Supporting Member
    Monterey Peninsula
    Noticed the horn sounds for lock notification even though windows are open.
  10. TT97
    TT97 Active Member
    Los Angeles
    On 21.9, I had about an 80% success rate disconnecting the charger without unlocking the doors. (100% if the car was pre-conditioning). With 28.1, I am at 100% success rate (although sample size is 1).
  11. JLove
    JLove Member
    Orlando, FL
    Ugh, I actually had 26.2 and had this happen all the time. Car kept starting and stopping charging like every minute when it hit the max charge I set it at. Called support and they saw the same so they forced an update to the car... 28.2. Looks like the update didn’t fix the issue. :( let us know if you hear anything else! I’ll post back if .2 fixes it.
  12. PoitNarf
    NJ
    Maybe the BMS (battery management system) boot loader update fixes this? Worth another call to Tesla support or your local service center. Ask them if your Model 3 needs that particular update and if they think that may fix the issue you’re experiencing.
  13. JLove
    JLove Member
    Orlando, FL
    Thanks! Saw the posts about it but didn’t even put two and two together. Will def ask them if it happens again!
  14. harcocjh
    harcocjh Member
    Chicago, IL
    Anyone else getting error messages now after this update? Maybe 28.2 addresses these erros.
  15. TT97
    TT97 Active Member
    Los Angeles
    What is the charge port lever?
  16. Boourns
    Boourns Active Member
    Dallas
    Still on 28.1 after a service center visit yesterday -- no 28.2.
    Bluetooth echo still present. Traffic rendering bug still present.
  17. MacGreiner
    MD
    Im on 28.2. Still have echo.
  18. chrishawn
    chrishawn Member
    Minneapolis, MN
    Now i know why everyone is getting it!
    Do I need to do anything to start my Enhanced Autopilot trial?
    No. If you have not already purchased Enhanced Autopilot on your Tesla, you will automatically qualify for the 14-day trial. Your car must be running software version 2018.28.1 or later before your trial can begin.
    Tesla
    • Informative x 3
  19. brobinson
    brobinson Member
    Ohio
    anyone else noticing the app and iOS widget not updating as often with this version?
  20. barjohn
    barjohn Member
    Riverside, CA
    Anything new in 28.2? Seems awful close to 28.1, I wonder if they found some bug in 28.1 that needed an update with a fix.
