In 3-5 years? Absolutely.
If the competition is still crap then probably. But it looks like the interior and MCU will be updated before thenI think you are correct. Will Tesla really wait that long before updating the S?
This is my understanding as well.I'm positive I believe that!
The issue, as I understand it, is that the rotor heats up. It is cooled, but only from the center shaft (co-axial coolant flow).
Mid point of discussion:
General Discussion: 2018 Investor Roundtable
Whereas Tesla has a patent for hollow rotor cooling of ACIM, is there any actual evidence this expensive/failure-prone design ever made it into production?
OTOH the MS internal diagnostics screen depicts the liquid cooling loop going through stator only, and if the rotor were also actively cooled methinks the motor should never have suffered from the heat fade issue:
It looks pretty clear to me that the rotor is listed as part of the cooling. (It even looks like the temperature is shown.) Or are you saying the Trans doesn't get any cooling either?
Yes, people have taken the motors apart and showed how the coolant flows through the rotor. But even doing that they can only cool so much with the contact just in the center.
That is just a block diagram illustration, not the real plumbing details.
You're both right, thanks for the correction! Just discovered that Jack Rickards did a very instructive MS motor teardown video in 2017.
Here is his cooling schematic -- coolant flows in and out through the same hollow end of the rotor axle:
@MP3Mike
Right again, I somehow managed to overlook that rotor coolant temp is reading 4x stator coolant temp!
