As noted above, this will not correct flat spotted tyres!Or pay £80 or whatever it is these days to get the wheels properly balanced and then inflated correctly.
read my thread mate. if they don’t fix it by balancing ask them to swap your wheels for the older 19" and go for a test drive and see if it helps because I am pretty sure mine has.Picked my AWD Highland up yesterday. Slight steering wheel vibration above 60mph. Booked in for a service visit.
Our expert advice: If your tyre shows signs of flat-spotting, make an appointment to service your car at a garage immediately. If it is not possible right away, change the tyres as quickly as possible to avoid irrevocable damage.
They always arrive with higher than recommended pressures.As an aside the recommended tyre pressure for my AWD is 42psi. The car came delivered with the pressure at 47psi.
You're being a bit over-dramatic. The slight flat spotting these tyres suffer from won't do any damage to the sidewalls and why do you think you're more likely to get punctures? It's annoying at most, but certainly not dangerous to drive on them. 27 psi is a bit low though IMO. OK to drive on for short distances and without putting any significant lateral load on them, but that's about it. Maybe double check the pressure they recommended and ask for it in writing.Had a call from Tesla today to say that their European headquarters have sent them instructions on how to fix the issue of vibrations and they say that this is due to flat spots on the tyres and they recommended that they lower the tyre pressure to 27psi and drive the car for 50 miles to fix the issue. This has really pissed me off as they want are basically saying that the tyres have been damaged due to flat spots and we will basically repair the tyres and give you back the car. I did my research and this is on michelins website
Semi-permanent tyre flat-spotting occurs after a complete standstill of at least four weeks. It can be aggravated if your car has had to withstand an additional weight load for a longer duration of time. This situation should not be taken lightly, as flat-spot tyres have a significantly higher chance of puncturing when driving.
it angers me that Tesla expect me now to drive a car thats had damage of flat spotting and then have driven the car for 50 miles at speeds of 50-70mph, which will do god knows what damage to the sidewalls, and then use the car with my 2 and 3 year old and have confidence that they tyres are perfectly fine !!!
I would guess that it is an attempt to reduce the likelihood of flat spotting whilst being transported.As an aside the recommended tyre pressure for my AWD is 42psi. The car came delivered with the pressure at 47psi.
Wouldn't it make it more likely ? Pressure applied to the tyre through being strapped down and a high pressure means that it's mainly going to be the rubber that deforms.I would guess that it is an attempt to reduce the likelihood of flat spotting whilst being transported.
The cars are strapped down, the higher pressure stops the rubber deforming - clearly needs to be a higher pressure for these tyres.Wouldn't it make it more likely ? Pressure applied to the tyre through being strapped down and a high pressure means that it's mainly going to be the rubber that deforms.
I'm no tyre scientist though.
The higher the pressure in the tyre the less deformation will take place ... (though it obviously hasn't been working!)Wouldn't it make it more likely ? Pressure applied to the tyre through being strapped down and a high pressure means that it's mainly going to be the rubber that deforms.
I have done some research and when a car has been stationary under heavy load (I think being strapped down tightly to the floor of a ship for a month that is being thrashed about in the sea constitutes that)can form "semi permanent" flat spots and its recommended to replace the tyres. I also personally think its a tad bit shitty that spending £54k on a car with tyres that have been damaged and then expect the customer to drive for 50 miles at 27psi to "fix" the tyres. Maybe you are right I am being a bit"over-dramatic" but I don’t know about you but I prefer that the only piece of the car that actually touches the road are in perfect order.You're being a bit over-dramatic. The slight flat spotting these tyres suffer from won't do any damage to the sidewalls and why do you think you're more likely to get punctures? It's annoying at most, but certainly not dangerous to drive on them. 27 psi is a bit low though IMO. OK to drive on for short distances and without putting any significant lateral load on them, but that's about it. Maybe double check the pressure they recommended and ask for it in writing.
My theory is it's more likely to be related to the longer sea journey around Africa... so strapped down for longer.The change of tyre construction to improve efficiency (and the reason for the lower top speed) means they are probably more prone to flat spotting during transportation.
Slight flat-spotting certainly doesn't mean you always have to replace the tyres. All the tyre manufacturers have advice on this if you do a bit more research.I have done some research and when a car has been stationary under heavy load (I think being strapped down tightly to the floor of a ship for a month that is being thrashed about in the sea constitutes that)can form "semi permanent" flat spots and its recommended to replace the tyres. I also personally think its a tad bit shitty that spending £54k on a car with tyres that have been damaged and then expect the customer to drive for 50 miles at 27psi to "fix" the tyres. Maybe you are right I am being a bit"over-dramatic" but I don’t know about you but I prefer that the only piece of the car that actually touches the road are in perfect order.
