That fixed it. Thanks!Try a hard reload of the page, we have moved some files around. Shift+reload button.
Thanks, that was a bug - now fixed!Another observation: The estimated cost to charge is no longer being displayed on the trip summary.
I think this is a bug: On a long trip with 10 supercharger stops, the plan has me arriving at the last supercharger before the destination with the "goal arrival charge" rather than the "charger arrival charge".
Edit: Actually, it seems to have something to do with the Florence SC supercharger. Try Ottawa Ontario to Orlando Florida. All the SC arrivals are at 10% except Florence, which is 15%.
@Dr. J, I'd say Tesla is incorrect. I charged at Plano back in May and it is definitely an Urban charger (or was at the time) and thus no higher than 72 kW. Charging details courtesy of Teslafi.comPlano? Tesla says it's 120kW:
Edit: Same with
Dallas, TX - North Central Expressway Supercharger
Edit: Same with
They were built in April and unless Tesla went in and changed them from urban to highpower in the last 3 weeks they are still urban. Teslas website is wrong.
@Darren S and @LCR1, I stand corrected. I've only charged in Plano once (and never in Dallas) on Oct. 18 and was billed for both Tier 1 and Tier 2 power (only 60 kW dividing line), but I was getting coffee and didn't observe the charge. That raises the question: how can you tell the difference between urban chargers and superchargers? Especially if the Tesla website is wrong.
I didn't even notice the difference between Plano's urban chargers and Arlington's superchargers, LOL. But I'd only owned my Model 3 less than a month, and I was distracted by showing my brother my fabulous new car.You could also use PlugShare and look at the photos to easily tell if it is an Urban charger.
@Dr. J, thanks for the update. You could also use PlugShare and look at the photos to easily tell if it is an Urban charger. You could also use supercharge.info which currently lists Plano as 72 kW although I was under the impression that this data was obtained from Tesla so I'm not sure. I see that A Better Route Planner has Plano listed at 120 kW. Photos would probably be the best way to identify each style but pick whichever version works best for you.
I have a first gen 90 kWh battery pack and have been throttled to ~95 kW max since 2 or 3 months after owning it (~June 2016) so I don't mind the consistent 72 kW from an Urban charger and it isn't that much slower than a conventional supercharger and is much more steady / reliable on charging speed for me.
@BlueShift gets his info from the public and this forum for updating supercharge.info. The laredo Charger was built and online before it ever showed up on his map because no one actually caught it and made a thread to tag him in. Take a look at a lot of the other locations and you'll see they have limited or incorrect info. For instance Corsicana is listed as 6 stalls when it has 10 or 12 since the expansion and no KW mention, Denton doesn't have a kW mention either. <snip>
<snip> My car being an older 70D maxes out around 115kw and I rarely ever even see that, it's mostly at 90ish and quickly falls from there. I've been looking at getting a 90D, do you have a thread handy that explains the difference in the 90 batteries and when they each came out?
Yes. Just use the settings icon to the right of a waypoint to set charge rate, percentage and/or time.Does ABRP simulate max charge rates for manual charging input? Say, you set 120 kW charging rate at a location, will it then simulate a supercharger session? This could be useful to plan routes where superchargers are under construction.
Well Blueshift is correct on this one (kudos to him) but I don't know how / when / what source he used to get the accurate info. Here is the official Tesla data (https://www.tesla.com/all-locations) as well as the supercharge.info data (https://supercharge.info/service/supercharge/allSites). Each set of data is generating the info on their respective site per the sample data in the comparison below.
I just don't know how or why Tesla would have the incorrect info when they installed it and monitor it constantly. Maybe it is wired for a future upgrade to a full 120 kW supercharger site but at the moment only has 72 kW Urban chargers. Hopefully not too many folks will expect to get 118 kW only to arrive and get just 70 kW. I wonder if there is a way to inform Tesla to update the info on their "Find Us" map and in-vehicle Nav screen so it is accurate to the location.
