This was a new owner, so I doubt that had anything to do with it. It was probably just a psychological choice made in the moment. Like some people prefer to sit in a corner with a view of the room.Someone posted that the temp stalls are faster than the permanent ones (perhaps because they are newer). Not sure how many 90kw chargers are left around the world
You mean early 2014 S85. I also supect the HVJB somewhat.My prediction: Early 2013 P85, second owner, Norway. The drive unit will have been replaced due to high failure rate. As part of the service the HVJB may have been serviced. During service, tech disconnected battery bolts. Later they were reconnected but inadequately. As a result, overheating occurred during supercharging. (Could equally apply to HVJB connecting to HVAC battery heater/AC chiller)
I wonder if the previous owner never supercharged, or hadn't done it since a service where the HVJB was opened, and the first thing the new owner did was to do a road trip. This would explain why it happened two days after a new owner took posession and it would fit with the approximate location of the ignition source.
Someone mentioned in the short-term investor thread that they didn't sense the temperature in the HVJB in the first revision, but that they added it to later revisions. The car in question is probably old enough to have the first revision.Right... 2014 for Europe (unless imported but then it wouldn't supercharge.) It could have been that the HVJB overheated at the higher charge rate, possibly due to a lower SOC. (New owner might have run the pack lower than expected.)
Tesla do sense the temperature at the charge connector for the supercharger, but I doubt they sense the temperature at internal components.
And without being Xenophobic, far more likely to happen to Americans than Brits
(It is impossible to refuel here without continuously holding the trigger on the pump nozzle, maybe this is why?)
Are you joking? Are you also leaving HUGE REMINDERS on ICE forums not to leave your kids in the back seats of cars while fueling at gas stations because of the danger of explosions?
you know, to kind of point out the obvious, this kinda is a HUGE REMINDER not to leave your kids in the back seat of your MS even for quick errands or a quick trip to the bathroom while supercharging.
This is all I've seen: Google OversetterHave any comments been posted on any media outlets from the owner of the car?
The Oslo-man wanted to celebrate an especially good year at work and bought a Tesla for himself.
- I just had the car delivered two days ago, says the owner to Dagbladet.
He is very downbeat after the car that was new to him is now just ashes and burnt-out car parts. He had lent the car to a coworker and when this coworker set the car to charge at Brokelandsheia by Gjerstad it went completely wrong. Shortly thereafter the car was engulfed in flames.
The fire was reported to the fire department at 2:40 pm new years day. It was one of Tesla's own rapid chargers that was used to replenish the batteries of the car.
- It started burning entirely by itself after my coworker had set it to charge, says the owner.
First and foremost, he is happy things turned out so well for his coworker, and that no one was harmed.
And an earlier one before the fire brigade arrived on scene:
I was mostly intrigued by the white smoke in the background.
I don't think the smoke is coming from the transformers. I think something happened to the car that threw white smoke, just before the picture was taken. Possibly a gas strut or something went off.This is the most helpful picture IMO.
1) Steam or smoke coming from the infrastructure cabinet appears to be a transformer smoking (failing)
Disagree. Looks like the fire is in the entire trunk/rear seat area.2) Fire appears to be initially isolated on the charging port side of the car.
But I would think they would sense DC voltage directly at the battery, inverter and charge port? This should detect a loose or poor connection under load in the HVJB (i.e driving, charging etc.).
Anyway, we are just guessing at a cause.
Have not seen anything in the main stream media. Surprising quiet.
