Geezzer
The fix is now available. Service Bulletin SB-19-39-001 R2 Dated 25 June 2019 applies and is a replacement of LH front drive unit Clovis mount and both front halfshaft. Applicable to all MX & MS 2014-2019 (before May 2019)
You can always ask of course, but I doubt you will get it if you are not experiencing the problem. The procedure is to test your car first and if they don't see a problem, you are unlikely to get the replacement. Never hurts to ask. You might get lucky. And right, it is not a recall.That's interesting. I haven't experienced the shudder problem (yet) on my 2018 MX but might ask for this update at next service while still in warranty. But I presume it won't be an official recall fix.
Yea, good point. I have heard where some SCs will say to put the car in low to lessen the issue of shutter. (not my idea of a solution on an expensive car like this). However, the mobile tech is directed to put the car in Standard height and try the acceleration to determine if it is a problem. I don't know about putting it in high and trying to cause the problem. Not something I would try, but I suppose it might cause the problem. I'm sure there are carrying opinions about this. My son's 2017 X doesn't have this issue and can't replicate it in standard height, but it seems to be a problem on a lot of cars as you know.But that’s pretty easy to replicate. SCs recommendation to avoid shudder was to put it in Low and reduce acceleration. So wouldn’t putting it in High and doing repeated launches cause the shudder?
Abuse for warranty is a concern though...
It seems the air under the car causes the problem.
Air? If it was air they could add a spoiler. It only happens on acceleration.. My take from reading this thread is that it is caused by the half shafts and only when the suspension is raised on acceleration.It seems the air under the car causes the problem.
Thank you for that detail. I couldn't find a link to the actual TSB. Would love to hear if anyone else who is Out of Warranty has managed to get this covered as a warranty service since the problem started while under warranty.The fix is now available. Service Bulletin SB-19-39-001 R2 Dated 25 June 2019 applies and is a replacement of LH front drive unit Clovis mount and both front halfshaft. Applicable to all MX & MS 2014-2019 (before May 2019)
What a load of crap. At least they fixed it, but the vibration most certainly causes loss of traction in some scenarios, and that obviously affects acceleration given that traction control is pretty much necessary for peak acceleration with that much instant power.This is exclusively an NVH issue and does not otherwise affect steering functionality, braking, or acceleration.
I have the shudder and I guarantee this has nothing to do with air under the car. If the ride height has an impact it is because of the geometry of the axles. Once I wasn't even accelerating hard at all and got a very severe shudder at 30 MPH. It was so bad I slowed the car. It has not returned, but I still have what I assume is the "regular" shudder that doesn't feel like a wheel is coming off.
Previous fixes have proven to only be temporary. This is purportedly a permanent fix.I'm confused. I had my X fixed for this exact problem a year ago. They knew what the problem was then.
The difference is the clevis mount. You didn't get it back then, and "possibly" got a different half-shaft.I'm confused. I had my X fixed for this exact problem a year ago. They knew what the problem was then.
It sounds like they didn't really have the parts on hand when they said. Else those tasks would have been done in half a day, I've noticed this happens often at some centers where no one really checks a day ahead of time to see if they have everything ready for the visit. You go in and find out they aren't ready. Best to call ahead and confirm, else waste your time. Also, this is the first time I have noticed that the clevis mount replacement is a part of the task.I may be mistaken but I think the current service bulletin is the 3rd design fix iteration for this issue.
My 2016 X90D has exhibited a pronounced shudder at 40-42 mph only when accelerating aggressively. Since I rarely have occasion to accelerate aggressively, I let it go until my recent 3rd annual service visit. At that time our newly established local service center was not equipped to perform the work and also needed to order the parts. They notified me a couple of weeks ago that they were ready. The fix was installed this past week along with a windshield wiper check valve replacement per a service bulletin. It took them 3 days. The car is now perfect.
Did they let you a loaner during those three days ?I may be mistaken but I think the current service bulletin is the 3rd design fix iteration for this issue.
