Thanks for all the response to my original post! Lots of good comments and ideas. To clarify a few points raised:
- When I left home the instrument cluster was displaying 263 miles of "rated" range. I understood this was probably more than I was going to achieve driving 65mph both uphill and down, but figured I'd at least come close. As it turns out, I made it just exactly the 201 miles needed. One mile further and I'd probably have been bricked!
Happy motoring to all and keep those Tesla grins going!
Someone could unplug you but the J1772 adapter is locked into the port while charging.
For family, might be worth paying to have a NEMA 14-50 outlet installed for your use if that is possible.
Obviously I'm glad you made it also. It still doesn't seem right to me that you averaged around 400 wh/mi doing no more than 65mph on cruise.
Anybody?
Depending on how comfortable you feel working with electricity... and how comfortable your relatives are with you tinkering in their distribution panel; an option I've used is to carry #6 SOOW cable ~100' with a NEMA 14-50 on the end. Then I simply connect it to the largest breaker that's not in use ~40 amp dryer or stove. Never have to worry about outlets cause I carry mine with me:wink: just remember to put everything back where you found it or you'll get a nasty phone call from your uncle asking why he can't dry his clothes...
The miles per hour based on 120 or 240 line of thinking needs to change. I switched my displays to indicate +KW instead of miles. You need to understand your average kW/mi figure and then know how many kilowatts are going back into your pack.
Sadly, I know many won't go through the trouble to do the calculations, but it is the most reliable way of understanding how long of a charge you'll need.
120v * 12amps = 1.44KW (maximum) per hour charge. Recalculate based on the actual voltage displayed onscreen (this number can fluctuate downward during peak hours during the day). I found that 120v has lower efficiency in charging than 240v due to some overhead, so I'll use 85% charging efficiency.
1.44kw * 85% efficiency = roughly 1.2kW / hr.
24hrs *1.2 = 28.8kw
vampire losses = -5kw per 24hrs
daily gain 23.8kw in optimal conditions, if it's too hot or too cold, the numbers can get even lower if the car has to heat the pack or run the cooling pumps, etc.
Just because we haven't invented a use for a unit doesn't make it not exist...(No such thing as kW / hr.)
"Grins / supercharge minute" anyone?Just because we haven't invented a use for a unit doesn't make it not exist...
Not knowing exact start/end points, I took an example of hartford <-> montpelier (route 91 all the way), and 2kW of accessory power (guesstimate), that's almost 400 Wh/m at 65 MPH ...
(using http://jurassictest.ch/GR/)
OK. I must not have enough experience with hills and headwinds. Interesting website. How do you get to the Wh/mi ?
