My take on the current charging curve is that it's the bare minimum to match other EV trucks, which it does and even surpass depending on your SoC window, while still being ultra conservative while Tesla gathers data and crank it up
It might be that they gain confidence and make it reach the quoted 15-85% in < 20 minutes, or the data gathered might show that this is it for this generation of cells and truck on the road
From all the charging tests I've seen so far in Teslas, it seems that their algorithm is voltage based, so for a given cell temperature and SoC, the voltage is allowed to rise to a given level, which current results in that is more or less irrelevant, provided it's under some hard limits for other components on the battery pack and charger
This matters because a big part of degradation happens with phase changes insides the cell, and high power at the phase change points leads to accelerated damage, so as they gather data and see how much they can push to each of those points, the charge curve can get fatter, or not, as I said above
Another way is letting the cells get hotter, since that lowers the internal resistance and allows for more current for a given SoC before reaching the voltage limit
