Nope, highly unlikely. If you have a monthly electric bill then it changes every month, depending on weather, how often you cook or use water, etc.
Also $7 charge is just another utility monthly fee, sometimes just called an access fee. Decoding the monthly fees often takes multiple months to figure out. And yes, they do it on purpose so you won’t try.
You likely have a kWh charge, and $0.12-$0.20 kWh are common. You might also have a grid charge for the transmission lines. That too is related to kWh.
To see how your monthly electric bill changes you need to measure actual circuit ( device) usage which usually starts at a $300-$500 box in your breaker panel or you can use averages. Compare last February year to this February this year. Was it colder or warmer? That can change your kWh.
It easiest to see how much your Tesla costs per mile by recharging at a Tesla supercharger. This year Tesla Superchargers are charging kWh at the std state utility rate, the same rate you use at home, provided the supercharger you use is in your state. Charge to 100% at home, then drive awhile, go to a supercharger and recharge to the original charge value. You could start at 80% at home, drive awhile, then recharge to 80%. Measure the miles driven and ($supercharger cost/miles driven. ) the supercharger cost shows up on your Model 3 display. And your credit card bill....
