Look at your app and see if it says Phone Key Connected. If you can easily see the car, odd are that it was connected.
It's indeed an issue, but there hasn't seemed to be a huge backlash. It's a big problem for people who park on the streets and the car still sees the key.
I do wish that there was some ability to easily mitigate the issue.
Irrelevant, the car COMMUNICATE via bluetooth, even if the address is the same, the phone need to reply with some sort of token to grant you access, so it doesn't matter, you simply can't have another phone unless he has the app opened WITH YOUR LOGIN!Pretty sure you are missing like four 0s on that number![]()
That makes sense. It would be hard for the cars to differentiate which one should openKind of related, When I press the charge button on the cable, my other model 3's charge port opens as well... Is that just a bug? I have never figured out why both car's charge ports open.
Phone key may show connected, but the car has a number of radios to determine how far away you are and allow unlock. This is very easy to test.
The most likely situations:
1) door was not fully closed when he exited
2) used key card to unlock car, didnt lock when walking away
3) trunk or frunk slightly ajar
The chances of keycards having the same 'code' is next to impossible.
This. To stop a phone from working as a key, all you have to do is delete the app, not remove the bluetooth connection. At least on iOS (all I have to test), deleting the app does not remove the bluetooth connections but the phone key stops working. So in the very unlikely event that "the wires got crossed" with the bluetooth connection (which didn't happen) the wrong phone still wouldn't work as a key.Irrelevant, the car COMMUNICATE via bluetooth, even if the address is the same, the phone need to reply with some sort of token to grant you access, so it doesn't matter, you simply can't have another phone unless he has the app opened WITH YOUR LOGIN!
A similar thing happened to me when picking my son up from soccer practice in May of 2019. There was a Dad and his son getting out of my car when we walked up. He was surprised to find it wasn't his car as his was 4-6 spots down. We were both needing to go so we didn't do any additional testing as I now wish we had. I have walk away locking and the fields we were walking from were 100+ yards away. I do have pin to drive enabled since I am in IT and understand every layer of security helps. It was definitely strange and concerning.
If any door is not completely latched the car won’t lock. That’s likely why he’s asking. You wouldn’t be the first.
I try to listen for the honk, but usually also look back at the car to make sure the mirrors are folded. Gotta agree though, it would be nice if the car would notify you (via the app would be simple I think).This happened to me on a couple occasions. It would be nice if the car would beep to let you know it was unable to lock.
You can see if it's locked in the app. But you have to open it. A nice feature would be to add an option for an app notification when the car locks.I try to listen for the honk, but usually also look back at the car to make sure the mirrors are folded. Gotta agree though, it would be nice if the car would notify you (via the app would be simple I think).
