How about integration with iPod Out functionality.
http://www.macrumors.com/2010/07/12/bmw-to-support-new-ipod-out-feature-in-ios-4/
Luckily the "want to coast" crowd is pretty tiny. It gains you nothing and is rarely needed vs regen.
Variable. It is all in the right pedal. The deadband you talk about is part of the smooth and continuous right pedal travel, and some complain because the exact "dead" (or coast) spot is hard to find or maintain. True, you still need to have your foot on the right pedal, because if you lift just a little too far, you are regen'ing instead of coasting. But coasting is possible. I like your idea though of a slider for adjusting WHERE (and how large) the deadband is, including at the zero position (completely off) of the accelerator.Question: Does the roadster have variable power regen, or is it all or nothing?
Which is sort of what they do. The brake lights do NOT come on immediately when regen starts. It has not been confirmed (from what I have read/heard) exactly what the trigger point or method is, but I believe the activation of the brake lights is based on the deceleration (# of g's), and -0.3g has been mentioned somewhere. But I also think the algorithm may be more complex at low speed.I agree with vfx (?) and think they should keep the brake lights off until the regen approaches 3. gear engine drag.
New idea: A special specific regen taillight. Perhaps the 3rd taillight only lights amber on regen.
Edit: Anyone with better or more official info on the "brake light algorithm" ?
I don't anticipate that adjustable brake settings will be in the car...too many regulatory/safety concerns, I'd bet.
They (all) design the speedo cluster to be seen when looking flat at the steering wheel. Great on the drawing board and in pictures but it ends up only working for people in the five foot range.
Making that display a touch screen is probably overkill given how little use it would get. But a customization program that your could run from your PC or on the 17 inch would be nice (and likely too complicated for John Q. Public). Hmmm... even better, if you can do your customization via browser in the cloud and that would then be synced to the car via cellular data connection. Tesla has already talked about display "themes". Perhaps users could share their various customizations.If the cluster LCD was touchscreen then they could allow you to drag and resize the gauges to your liking.
I'd like to feel a bit of feedback from the pedals at the 'go faster' end of this deadzone - a tiny change in the pressure required so that I can rest the pedal against it. This could also be set via software.I think I would prefer "roadster type" regen, but with a slight deadband for coasting. In a car with front wheel drive or four wheel drive, though, I think the addition of even more regen with the brake pedal might be good. There are limits to how hard you can regen with the rear wheels only. Regen on the front wheels or all four can be far more powerful.
All of this will be controlled by software, so the best solution would be to make deadbands, extra regen when braking etc customizable. A slider for adjusting deadband and another to shift regen between brake pedal and accelerator would do it. Leave the first centimeter or so of pedal travel to variable regen control.
Don’t confuse customization with aftermarket customizing
We've heard a lot of really nice features in the Model S, but did anyone check out our wish list? Here are some of the things I really want, which I assume the Model S will have. Can anyone confirm?
*Adaptive cruise control
*Folding and auto-dimming outside mirrors with memory feature
*Rear parking assist, camera or simply acoustic measure
*Auto-Dimming rear-view mirror
*Electrically adjusted seats with memory
*Blind spot monitor
*Lane departure warning system
