Sorry, I don’t think I am a little wrong.Lol. The math is still wrong. But peace since were both a little wrong. Lets both ignore the theoretical.
My empirical says that my cig lighter inflator works fine. So you can take that to the bank.
Good point! The basic message I’m hearing from people responding to this thread is that all of these 12V inflators will work with the 16V battery since they need to be designed to work while an alternator is running. I also haven’t heard from anyone saying their inflator blew a fuse when they ran it off of a 16V battery, so I suppose I just need to go out and buy one!You are overthinking this, simply purchase any 12v rated inflator. It is not uncommon for any standard car to reach up to 15v when the alternator has a demand. A 12v battery is not actually 12v, more like 12.7 and on a float charge around 13.2.
In fact, for Tesla with 12v battery, when the car sleeping:You make a good point that on ICE cars, there will be more than 12V on the 12V outlets while the engine is running.
Why not using an inflater designed for 16 V.I made an adapter with a 12v aux cable and a buck-boost converter to take the 15.5V of the battery and step it down to the 12v
No, Ohm's Law is only for ohmic loads. And motors aren't ohmic loads.You guys are killing me! No no no! Ohm’s law is not for pure resistive loads only, it applies just as well to coil impedance (resistance and reactance) such as a motor coil.
Well I can't think of any circumstance where the current goes down as voltage goes up. But Ohm's Law describes a linear relationship between voltage and current and with motors, you don't get that.At least you’re not claiming that current will go down as I apply more voltage to a DC motor, unlike a few of the other helpful posts here.
For AC voltages, when you use a step up transformer the amperage on secondary side will be proportionally lower than the amperage on the primary side of the transformer for the same circuit impedance. I.e. when you double the windings on the secondary side as compared to the primary side the secondary side will see twice the voltage and half the current. If you have 10X the windings on the secondary as the primary the voltage will increase by 10X on the secondary side and the current will be reduced to 1/10.No, Ohm's Law is only for ohmic loads. And motors aren't ohmic loads.
Keep doubling down, man. Ohm’s law (V = IZ) absolutely works with DC motors, as long as you use impedance (not DC resistance) and account for back-EMF. Not sure what else there is for me to say if you continue to disagree with physics.No, Ohm's Law is only for ohmic loads. And motors aren't ohmic loads.
Thanks! I’m actively considering that one, since it is sanctioned for the MY by Tesla. I’m unlikely to use the slime repair kit (would prefer to plug) but the inflator looks attractive. I’m glad to hear it is working for you!I bought the official Tesla one and it works
Okay, sure. But I'm talking about from the perspective of whatever is feeding voltage into the circuit. Say you're controlling a power source and you have a dial that controls voltage, and the power source tells you what the current is going into that circuit. The circuit is a black box and the only thing you know about it is that it doesn't have a power source in it, and it's composed of passive components only. You turn the dial and crank up the voltage. Can you think of any scenario where you crank the voltage up and the current goes down? If it's feeding a transformer, the primary voltage increases, and the secondary voltage increases, and whatever that secondary voltage is driving takes on increased current, which increases the current in the primary as well.For AC voltages, when you use a step up transformer the amperage on secondary side will be proportionally lower than the amperage on the primary side of the transformer for the same circuit impedance. I.e. when you double the windings on the secondary side as compared to the primary side the secondary side will see twice the voltage and half the current. If you have 10X the windings on the secondary as the primary the voltage will increase by 10X on the secondary side and the current will be reduced to 1/10.
This principle is how AC power is distributed over long distances using high voltage AC power lines with relatively little loss due to resistance.
Ohm's law only applies if Z is constant for all V. With a motor, it's not. And you just mentioned one reason why: the back EMF.Keep doubling down, man. Ohm’s law (V = IZ) absolutely works with DC motors, as long as you use impedance (not DC resistance) and account for back-EMF. Not sure what else there is for me to say if you continue to disagree with physics.
Ooooh that looks nice! Not too interested in the cordless feature, but I would assume the DC motor is rated to 20V. Thank you!I have a craftsman inflator. It works in the Tesla 12v outlet, can plug into a standard home 120v outlet and can use a craftsman 20v rechargeable battery. I've used it a lot over the years. Every so often it goes on sale.
I paid $59 but I got it a few years ago.Ooooh that looks nice! Not too interested in the cordless feature, but I would assume the DC motor is rated to 20V. Thank you!
In truth I carried a foot-pump for tire inflation back in the day and actually used it a lot. It always worked.
Except when theses 12V devices are power inverters. Some models of inverter cannot handle 16V DC input. Also, some Tesla Model Y owners with the new low voltage system (Tesla no longer calls this a 12V system) have experienced issues when connecting trailer lights.There are two questions implied in the OP:
1. Will a couple more volts blow up the DC motor in a "12v' device. No
2. Will a couple more volts blow a fuse due to the increase in current ? Very unlikely.
That is the electric answer. The trivial answer is that if Tesla put a '12v' receptacle in these cars that are powered by the li'l LFP, then '12v' devices are fine to use.
I generally agree with your comments, and am less concerned now than when I started this thread. That said, I do think it is important to pay attention to electrical specs. Many cars on the market have 10a fuses on their aux outlets, which can easily be blown with a 15a inflator. Incidentally, the MY has 15a fuses on these outlets. Plus (as @jcanoe points out above), Tesla specifically warns about power inverters that may not be able to handle 16v. So it’s worth paying attention to these things. I don’t think a 12v marking on the outlet always means “good to go.”There are two questions implied in the OP:
Current on a motor is based on the load of the motor (how much pressure is in the tire). Does your Tesla use the same watts at all speeds, slopes and acceleration?Thanks! And you have the latest 16V battery? I’m curious how often you’ve inflated your tires with it. My biggest concern is the fuse in the inflator. The inflator will draw 33% more current from a 16V battery. It might also exceed the 15A current rating for the outlet.
