tl;dr: No matter the conditions, climate control starts at full speed on floor vents when started in auto mode or when started remotely from app.
Excessive details:
For the past two weeks (since July 18) I have had a consistent issue with my HVAC in auto mode and with remote pre-conditioning. Whenever the car starts with air conditioning in auto, or whenever climate control is started remotely, it swaps to floor vents with the fan at full speed. It's obnoxiously loud from the outside of the car, and when you get in there's a foot-tornado occurring.
I first noticed this also affected remote climate control the next day, when 20 minutes after I started preconditioning, the interior temp had only dropped a few degrees when I opened the app. As I was heading out I could hear the HVAC system in turbo mode from about 30-40 yards. When it's really hot outside, the air just can't get very cold at those fans speeds, so it's really ineffective at cooling.
I’ve tried several scroll wheel reboots, driver profile changes, different HVAC configurations, etc. but have had no success with anything. I reported to Tesla (ServiceHelpNA) on July 23, and they forwarded it to my service center, but I have not heard back from the service center.
While I'm in the car, I can fix it temporarily by changing climate control to manual mode, activating the forward vents and turning off floor vents, and then put it back in auto. From this point it works fine in auto and remains on the forward facing vents as long as the car remains on. But once the car shuts down, HVAC starts back up on floor vents the next time the car is started or when remote climate control is engaged.
I also ran a test in my garage by letting the cabin get down to the set temperature and then shutting the car down. When the car restarted, HVAC still went to floor vents at full speed despite the interior temp matching the set temp. I've seen it eventually get down to 66 degrees in the car when the temperature was set to 74 after the sun went down.
I can get around the auto mode issue by just staying in manual, but this doesn't fix the remote climate control issue. Apparently when you activate it from the app, it uses auto mode despite how it was set when you left it. Once you get there and open the door, it switches back to manual and to the forward vents and last fan speed. So I've stopped preconditioning entirely in order to avoid passersby thinking a Tesla is about to catastrophically explode. Plus it's just not very effective as noted above.
The only thing I know of that may have contributed to this is I had performed a few resets on July 18 (at the request of service) to attempt to address an issue with my passenger side signature LED strip being out. I think I also created a new driver profile that day. I was and still am on 21.9, so I'm not sure if a firmware update will reset it to normal.
I've searched far and wide and cannot find this issue documented anywhere. Has anyone else experienced anything like this?
Excessive details:
