What proof do you have that it is robust right off the bat, because a Waymo employee said so? Come on.
They did "what" in LA? Deploy robotaxis right off the bat? I don't think so. No one implied its going to work terribly right off the bat, just not at the same high reliability as it is in SF / Chandler right off the bat.
But that reliability off the bat is higher than Tesla FSD...Which is the entire point.
Yet people say that Waymo isn't scalable but Tesla FSD with the only barometer being you can activate it.
Actions speak louder than words, and Waymo's actions mean they need to collect data in every city to update their model. Meaning they will do the same collection in most cities they open up to for at least several years. There is nothing wrong with this, it just means the global robust model is a work in progress. And not scalable "quickly". But you could certainly argue Waymo cannot scale quickly because of other issues, so maybe it is irrelevant to them.
Atleast several years? They went from full-scale testing in LA in October 19th 2022 to Driverless at night in March 7th.
That's 4.5 months. Then they went driverless in daytime (24/7) around May/June.
So thats around 6-7 months to go 24/7 Driverless in a ~50sq mile area after full scale testing.
Does anyone think Waymo will be working / operating in all suburbs and middle density cities across the U.S in the next 5 years? Not a chance.
The problem is that you are not evaluating Waymo logically.
If you did, you will clearly see the trajectory of improvement.
How long it took Waymo after they started doing full-scale testing in SF to go 24/7 driverless.
How long it took Waymo after they started doing full-scale testing in LA to go 24/7 driverless.
A logical person will compare and see the difference in time.
Then the question becomes, how low can they get the time between testing to 24/7 driverless?
Then also what timeline delta is low enough for the company to be able to attempt to deploy at multiple cities simultaneously?
Once you answer these two questions, you can logically come to a conclusion for 5 years outlook.
For example the trajectory points to I believe 3 months by end of the year / Early 2024.
And I believe with it down to 3 months, you can then simultanously do full scale testing in 3+ cities.
If you project out 3 cities every quarter from 2024 for 5 years you get 60 cities.
Trajectory of improvement is also happening in its abilities aka ODD.
It went from just handling surburb, light rain and zero construction to being able to handle environments that include city, urban, heavy rain, heavy fog and constructions. All while being driverless.
I don't see you ever mention this.
The point isn't that Tesla is ahead from a pure technology standpoint, the point is that if Tesla's goal is to be able to operate basically anywhere, they have to build software that is very robust geographically, meaning they have to try to find the right algorithms and architectures sooner rather than later. This means generally worse performance in a selected subset of areas (e.g. SF) than if they had focused on getting maps / planning to work well in one area at a time.
If that's the case and logic then Huawei is ahead of Waymo...
You can't pick and choose how to apply that logic.
Blader is right to say Tesla isn't scalable at 100 miles / disengagement. But we all know most of those important disengagements are due to the very fact they don't understand how to navigate all these intersections across the U.S. yet robustly. And they are actively working on solutions to that problem. Solving these problems using a robust data set means that once they are solved, they are solved for basically everywhere. That's scalable.
I am bullish in the medium term because I think dominance will come from the ability to work basically anywhere, and Waymo / Cruise won't even be competitors in that domain. They just simply won't be in enough places even in 3 years, it will basically be small contributions to probably 30-50 downtown / urban areas.
Unless Tesla FSD is driverless everywhere in the USA. Then it doesn't have the ability to "work basically anywhere".
This myth is the same thing that Tesla fans always hold on to, that some day Tesla FSD will magically be L5.
So no matter how good Waymo is, they will claim Tesla is better due to some non-existent magic.
