stopcrazypp
The problem is most people don't give a sh*t about these specifics (you can tell by how much the general public knows about ICE cars). Some people are enthusiastic (like us), most people don't care. You can see the battery bricking issue for a fine example (Tesla laid out a very clear description of the discharge timing in the manual that was largely ignored).Well, Tesla's going to need to find a way to make that discussion possible because people are going to want to know and they'll feel very uncomfortable and untrusting with vague answers.
Then that sounds like the educational material Tesla needs to put together. I'm not trying to be a hardass here, people are going to want to know. George B even talks about how the stores are about educating people on EVs. This seems like a good fit of purpose.
It's not just "semantics". "Damage" is orders of magnitude worse than "wear" and is usually used to describe issues that lead to the need for immediate total replacement or repair of a part, which is why it's not used except in very specific situations. For example, there are certain roads that put extra wear on tires, but you would not call it "damage". However, if a nail punctured your tire, it would be called "damage".This is just quibbling semantics. It all boils down to "I do X and the battery gets worse by Y". Very few people, including fairly technical people like me, are going to care about the technical classifications of why Y gets worse. You might argue they should care, but that's fighting human nature and that battle is lost before it's started.
In the same vein, charging in Range mode (and storing it for long periods of time, like the worse case I point out) would not lead to your battery needing immediate replacement or repair. The battery will just wear faster than normal. As in your 1 year old battery looking as if it's a 3 year old battery. However, if you fully discharged it and left it there so that it is under-voltage (this is real damage), your battery would need replacement or repair.
