Jason71
220 miles at 510wh/mi would have been a usable capacity of 112kwh which is much greater than the capacity of your battery so when you were getting 220miles you must have been averaging much less than the 510wh/m you say you are getting now so your consumption clearly has gone upfor info- I get 122 miles from 100% to 0% charge, I used to get 220 ish. I use about 510wh/mi on Ave, so I’m not trashing it…. And it’s the commute I’ve always done…. I’m just wondering if it’s the cold weather? Or if something is wrong?…. I commute about 100 miles per day and now have to charge to 100% to make the trip, and am on amber/red batt when I get back….before (august) an 80% charge did the trip easily with no range anxiety….. hope that info helps
Winter will make a big difference. less so on long journeys but still a big difference. you are likely to see a winter range drop of 20+%.
In the really cold weather we had pre-Christmas that might be more like 30%.
I don't know what the typical wh/m for an X is so not sure if yours is high.
What does the new more detailed energy graph in the car show about your usage?
My top tips for Winter range are pre heat well on mains power then turn the heater fan down to low and put the heated seat on. Did 2019 X have heat pumps? if not then this is will make more of a difference.
