Trembling9653
Yup original battery and original owner. Yes Insane only.Original battery? Insane and not Ludicrous?
When was the car sold new? Was it october 2015 or later? Was you battery ever removed for any kind of service?Yup original battery and original owner. Yes Insane only.
If the fuse they replace is the battery powered pyro fuse, that battery has a lifetime, like most Lithium batteries, of about 10 years. If your battery warranty was still in effect, there would be no charge. It seems to me they should replace yours at no charge as a goodwill gesture.
In 2012, they didn't have a self powered pyro fuse. They all had a battery. If that was replaced at some point, it likely would have the newer versions, which are self powered. If it is some other fuse, it is unusual for it to go bad, but your car is 12 years old. Good luck to you for a less expensive service visit..
They never had a warning for this issue before, and it is a safety issue. The feds would really be upset if a known safety issue was not proactively corrected, of course, at your expense. They are now making sure the older cars are as safe as possible. At least I hope that is the primary reason.
Sure. They can open it up and check. But if it’s a fuse that doesn’t need to be replaced, it really should be free.If it's a safety issue due to Tesla's design flaw then it shouldn't be at the owners expense.
