Sorry, I was asking @TexasEV if the warning about charging to full occurs only at 100% or 91%-100%. I should have actually quoted them.Nah, think it just continues to drain every day. I've never had it over 90%. Either way, it's way off, not just by 1-2%.
I’ve never set the slider between 90 and 100% so I don’t know for sure, but it’s unlikely to trigger the warning as the two options on the original Model S firmware were daily (92%) and trip (100%).Sorry, I was asking @TexasEV if the warning about charging to full occurs only at 100% or 91%-100%. I should have actually quoted them.
No, an original 60 from 2013.was your S 60 a software limited battery?
That is nowhere near correct. The EPA test cycle includes various speed, temperature, and duration to mimic city and highway driving, and some with air conditioning. Search EPA test cycle for detailed explanations of the test methods.EPA rating is done going 50 mph on cruise control on a flat road with no wind and the A/C off, and under normal ambient temperature conditions (is what Tesla told me)
Nitpicker's corner:the original Model S firmware were daily (92%) and trip (100%).
No way I can do 310 miles.. I have the 19 inch sport wheelsAny vampire drain would be reflected as soon as you turned on the car. If you're seeing a range drop after you started driving it's because of your driving style. AC, aggressive acceleration, high speed with all contribute to the range going down. You can definitely achieve or exceed 310 miles of range with efficient driving.
I've driven less than 50 miles since then and the range is now down to 163 miles! What is going on?
With the Aeros on I can get around 310 driving at 70mph. Taking maximum advantage of regen will also increase your range.No way I can do 310 miles.. I have the 19 inch sport wheels
..unless maybe I average 60mph on the freeway..
No one has mentioned it because it doesn’t exist in the Model 3. I know S and X owners are trying to be be helpful but please don’t assume the firmware is the same.No one has mentioned to turn off Always Connected. That keeps the car awake and prevents deep sleep mode. When my MS was new I had loss issues due to lack of sleep but now negligible- hope it helps.
On a long trips on the highway regen probably doesn't make a huge difference but I noticed it makes a huge different on a short drives. I like looking at the power consumption and I notice the average go way down each time I come to a complete stop with regen during city driving.Same here. 300 mi trip 150 mi each way, about half 75- 80 mph fwy and half 55-65 two-lane. Got a little over 318. I'm used to EVs and don't do a lot of throttle changing, drive gently unless I'm passing a Corvette, etc. With Aeros, which I think look cool and actually do something.
I suspect that regen won't make a lot of difference. It's likely how you drive, and should be embraced. I mean, we're talking a few cents on a trip. The enjoyment is worth the price of admission.
"Yeah, they say it'll get 325 miles per charge, but it's too much of a sport, so I don't quite get that much".
