Can anyone help with this? Model Y performance. 2022. Only 15,000kms.
Front by the headlights, happened lately a few times.Where did you observe signs of vapor? Steam requires water to be heated above 100C. No components in the Tesla Model Y reach 100C while charging due to the cooling system. Perhaps your Tesla Model Y has a coolant leak. Check the overflow reservoir that is located in the frunk under plastic shroud on the passenger side for a low coolant level. Also check for signs of a coolant leak (blue liquid, slippery when touched) underneath the Tesla Model Y while parked. A coolant leak is a serious issue and you should have Tesla Service inspect the vehicle as soon as possible. You should not drive the Tesla Model Y if there is a coolant leak.
That would be where I would check for any sign of coolant leaking, dripping onto the floor/ground underneath the Model Y. (In 2.5 years of ownership I have never observed any steam coming from my Model Y when charging or otherwise.)Front by the headlights, happened lately a few times.
supercharging or just level2. if it's level 2 there could be a problem. sometimes supercharging will smoke because it get's way hotter and there can be moisture from the overflow under the frunk. mine did this a few times around 15,000kCan anyone help with this? Model Y performance. 2022. Only 15,000kms.
Yes. Has never happened to me but I've heard of it. You could web search "tesla battery steaming after supercharging"Yes. Is that normal then?
