If you are installing new, the usual options are:
- 40A or 50A circuit with NEMA 14-50 or 6-50 outlet and use the mobile connector in the car with the $45 plug adapter to charge at 32A.
- 60A circuit with hardwired $495 wall connector to charge at 48A if your car will do it (RWD/SR+ does 32A, while LR/P does 48A).
The wall connector solution will be about $300 more ($495 - $45 plug adapter - ~$50 outlet - ~$100 GFCI breaker) plus any upcharge for the larger wiring needed to handle 60A versus 50A or 40A.
Questions to ask:
- Do you want the higher charging rate or extra features of the wall connector (versus the mobile connector)?
- Do you frequently need to have the mobile connector in the car for road trips involving charging other than Superchargers or other existing charging stations (i.e. charging at RV parks, houses not set up with EVSEs, etc.)? (Frequent plugging and unplugging from the 14-50 or 6-50 outlet is not recommended, although the plug-in setup is convenient for occasional removal and replacement needs.)
- Do you not anticipate needing to install a J1772 EVSE for an existing or future J1772 EV, or are OK using a Tesla-EVSE-to-J1772 adapter for it? (Note: Tesla cars come with a J1772-to-Tesla adapter, so they can use J1772 EVSEs.)
More "yes" answers to the above favor the wall connector, while more "no" answers above favor using the outlet with the mobile connector.
