  • Please check out the latest TMC Podcast (#13) where we discussed new Model Y launches, Tesla improving service, nationwide EV charging expansion, and viewer comments from previous episodes YouTube or listen to it on all major podcast networks.
Vendor Calipers vinyl wrap for Model 3
2022 M3 LR - I’m about to paint mine, orange. I cannot understand how someone would think that they don’t have the tools or skills to remove a tire. Good lord, how would one replace a flat tire or rotate them??? I’m amazed that one would think it is easier to clean the calipers and apply the vinyl through the wheel spokes than to just jack up the car and pull a tire.
The only reason I haven’t painted mine yet is because I want all 4 corners up and paint them at the same time. At least your vinyl makes it easy to do this one at a time. Seems like you have a great idea.
I had been thimking of painting mt calipers also. What method are you going to use when you do it...G2 or a spray like VHT?
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Thanks! In all fairness though, painting the calipers or replacing them with sports calipers looks better than vinyl covers, especially on the 3/Y where the default calipers are kind of so-so... (i.e. no big flat surfaces, metal lines sticking up or down etc...all that shows from under the vinyl). But the vinyl option is obviously much cheaper and faster, and still gives some color pop to the area. Let's see how it goes :)
I already bought the G2. I’ll clean the calipers, tape em off, and brush on the paint on all 4 corners at once (well, as close to the same time as possible). I expect to get two coats. I’ll let it sit a good 24 hours before putting the wheels back on.
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Hey guys
Status update - I am almost there now :) Look!
I am likely going to release it in 2 size variations - Rookie and Pro. Rookie will be a smaller fit that won't require you to remove the wheel (also cheaper as less material usage) and Pro being a fuller fit that wraps around (what I show here on these photos) that will require that you remove the wheel so you get access. I am yet to see about this though, as currently, to make my work easier, I work without a wheel. Once I put it back on, I will see how difficult it is to install the Pro version with the wheel on, it may turn out to be OK.
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Finally ready!!!
You can now get the caliper vinyl covers for the Model 3 here:
I will edit & publish the install video within a day or two. I ended up doing 2 versions - Pro and Basic. Pro requires that you take the wheels off and wraps around. The basic one is simply peel & stick and there is no need to take the wheels off, but covers a lot less and looks flat (although it still gives color to the area).
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Just get it installed. The cut and finished is greatt! But I will agree with canasion35. If we can get the front more coverage that will be 100% perfect.
will post some photo later
Hey thanks for the feedback! Just to get an idea - did you do the Basic or Pro version? Also do you mean extra coverage in the two arches (top and bottom) behind the front plate of the caliper?
Reactions: iyordanov
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Agree, the front definitely needs more coverage on the outside portion of the caliper. It looks unfinished. They do look great otherwise! Is the tesla lettering cut out on these as well or is there an overlay vinyl?
Thanks for the pics!
Thanks!
To answer your question - the letters are a cutout. I hope that the letters will be on the same spot on all cars, because I also do this for Model S/X and some % of cars have the letters on a different place for some reason 🤦‍♂️
On the coverage - what is your idea? To cover the two arches that go behind (on the front caliper)?
Reactions: PauliePucks
Thanks!
Yes, the two arches behind would make it look more complete, even if you managed to wrap them on the prominent face only so it appeared fully wrapped.
I know there could potentially be IP issues, but maybe instead of the cutout lettering, offer an option of solid wrap and include the lettering as an overlay?
Just a thought!
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Just a thought!
Thanks, noted, will add it to my todo to work on this when I find the time.
As for the letter being overlay - I tried that, but they are so tiny that weeding them is a nightmare...not scalable at all, so I've decided against it. I might at some point start printing them though.
It's too small on the 3 to be made...it literally can't stick on this small thing. Or am I mistaken of what's wanted? 🤔
The equivalent of this but for the 3?
iyordanov
Global Vendor
May 31, 2021
422
745
Bay Area
Just checked my wife's model 3... so the lip part of the black plastic under the rear bumper is tiny...not really a viable product I think.
Perhaps the entire plastic though, not just the lip?
