New I ordered my MX with Accessory hitch (as I am planning to use it for a bike rack only) when it was possible to order that or Towing package.
Yesterday, I decided to check out what was on my car and I think I got the actual towing package instead of the Accessory hitch.
I have read through the entire "Can I Tow" thread (I advise you to do so) and am not entirely clear on this situation. Here is what appears to be the case, tell me if I'm wrong:
All Model X currently being built include the hitch receiver and trailer electronics harness connector (7 pin plug).
You only get the Tow Mode software package if you bought the $750 Towing Package option which enables the software for Trailer Mode so the car will communicate with the trailer harness connector (7 pin plug) and will operate the trailer brakes (if they are electric) and "monitor trailer sway".
The "Accessory hitch" that some refer to is actually the "Model X Hitch Rack" that is sold through the online Shop at Tesla — Model X Hitch Rack
You can buy the Model X Hitch Rack without buying the Towing Package option and you will be able to use the Hitch Rack because every Model X is build with the hitch receiver (as I noted above).
Do I have all that right?
Still confused about this: I do wonder why Tesla uses the term "Tow Mode" for the $750 trailer towing option when in the center display Settings / Service & Reset / Tow Mode since that function is for setting your car to be towable by a tow truck. It is not for towing a trailer! That is confusing. If you have the "Tow Mode software package" that control is found under Controls / Driving / Trailer Mode
Really Tesla, you sell an option called "Towing Package" which gives you a control in the center display called "Trailer Mode"?
Recommendation:
Change the existing "Tow Mode" control text label in the center display to "Emergency Towing Mode".
Change the option name "Towing Package" to "Trailer Towing Package" on the Model X configuration page, and then be consistent and change the "Trailer Mode" control on the center display to "Trailer Towing Mode,"
The key distinction is "Emergency Towing" vs. "Trailer Towing". Everyone should be able to understand that.
