Do you see the Tesla-Android_8155 network? Does it have a green check mark next to it when you connect?tried single board. I can’t connect to the pi in the Tesla. I’m able to connect to the wifi from a pc but can’t load page 9.9.0.1. Anyone else?
Theoretically feasible. Even if there was someone dedicated to developing the code to make it happen, no way in hell am I going to root the OS of my Tesla, even as crazy as I am to make CarPlay work.can a rooted tesla run the necessary carplay binaries? this avoids the wifi / raspberry pi / hdmi setup. the software will run directly on CID
is this feasible?
I'd love if someone could do itTheoretically feasible. Even if there was someone dedicated to developing the code to make it happen, no way in hell am I going to root the OS of my Tesla, even as crazy as I am to make CarPlay work.
Regarding t he Hdmi to CSI-2, it seems there are two models of this board which work in Raspberry Pie 4. One supports video & audio and the other only supports video. I suspect we need to use the model which supports video & audio. Timeshifter seems to be using the model which supports video & audio too. Geekworm Raspberry Pi Hdmi to CSI-2 Module X630 is the version which supports video & audio. The other model C779 only supports video. According to the current tesla android project docs, Siri voice (navigations, responding to requests) is transmitted via the Tesla web browser stream which implies the need for using the module which supports encoding the pie's video & audio. Other types of audio are transmitted via Bluetooth.Below is how i have things connected. I have the micro usb to hdmi cable With one end connected to the pi and the other end connected to the hdmi board (Geekworm C779) Also, i can’t even connect to the pi from my tesla. I see the Wi-Fi (Tesla-adroid 3018) but when i try and connect, it says unable to obtain up address.
Based off earlier post, looks like bought the video only board. I went ahead and purchased the one you have. Hopefully that fixes my issues@Greybeard707 this is a photo of the underside of my Geekworm card
After studying this further it looks like you and I have different cards. They're both for sale on the same Amazon page as two variations. One is the "black" variant (mine) and it looks like yours is the "green" variant.
Your usb-c is not supplying enough power it seems. Heavily taxed pi 4 needs “5V DC via USB-C connector (minimum 3A*). A good quality 2.5A power supply can be used if downstream USB peripherals consume less than 500mA in total.“ Not all peripherals in the pi will get power in such situations. Source: Raspberry Pi 4 Model B specifications – Raspberry PiHad some issues tonight that might be worth noting. So, I took my system out to take some pics. When I reconnected it I decided to skip my 12V adapter and use the lone USB-C port in the console (the other is a USB-A). I first hooked it up with my voltage tester inline. It shows 5.01V and 1.17A. I may switch to the USB-A port, as I was able to draw 5V 1.6A on it when I tested it before. Are the USB ports always powered?
About 2-3 minutes in I selected Tesla-Android_8155 from the WiFi menu in the car. I got the red caution that it could not join and unable to obtain an IP address. I'd hit retry then it'd ask for the WiFi password, then fail. About 7 minutes after that I was able to connect. My phone connected and CarPlay was working and all was right with the world. Still had the tester inline.
So I disconnected the system and removed the tester and plugged in directly to the USB-C port. I had similar issues connecting but eventually it connected. But I couldn't get it going all the way. When I browsed to 9.9.0.1 I could tap the top left corner banner and view the release notes. But otherwise got a spinning red circle in the middle. From my laptop I could connect with similar behavior. I could ping 9.9.0.1 and out to the Internet at 8.8.8.8. So I think the system was up but the display service wasn't fully functional.
I took the capture card off, flipped the cable around and reseated it, put it back together and got it going again. I did have trouble connecting to WiFi at first. It seems that WiFi will come on, maybe about 2-3 minutes after power on. Then it goes off (noticed this by scanning with my laptop). I think that is consistent with being told to put in the WiFi password and other failures. Seems that the SSID is broadcast after the first 2-3 minutes, then shuts off, then comes back.
This.connect to Bluetooth so the sound comes from Bluetooth and the visuals are in the browser?
How did you fix your issue mentioned in #44 ? This could help another user.Ok I’m finally up and running. So pi connects to Tesla via Bluetooth and phone connects to pi?
