Charge port lights... Dying again...
Discussion in 'Model S: Battery & Charging' started by SabrToothSqrl, Jul 8, 2015.
  1. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    So, apparently my charge port hates me. This is the second one on the car, and I really don't want to drive 2 hours to the service center. Getting really tired of this... The lights aren't lighting up... Again.
    Is there anything I can do?
  2. Johan
    Johan Took a TSLA bear test. Came back negative.
    Drammen, Norway
    I mean give it time, just don't ram the cable in there every day. Every charge port needs a bit of foreplay. Also some KY Jelly or Vaseline could help.
  3. AnOutsider
    AnOutsider S532 # XS27
    Mine are dull on half the ring. Can't you just put it off til annual service? Doesn't affect operation, right?
  4. Zextraterrestrial
    Humboldt/Los Altos
    that's what I am doing. I went in to service and they thought I meant the magnet latch wasn't working but to replace the lights takes longer..I didn't have time to wait.
    second one too. Kind of pretty with red lights and green when charging or magenta instead of blue
  5. SabrToothSqrl
    PA
    Correct, it doesn't appear to impact charge function. I don't usually resort to KY until there's smoke.
    I don't do an annual service, but yea, I'll get it replaced a week before its out of warranty, unless something else creeps up between now and then.
  6. Todd Burch
    Todd Burch Electron Pilot
    Smithfield, VA
    I thought those puppies were LEDs. Are they not?
    If LEDs I thought they'd be either on or off, and very reliable.
  7. SabrToothSqrl
    PA
    They are, and they should be...
  8. Todd Burch
    Smithfield, VA
    By the way, I'm not sure I see the issue in your screenshot. Is that a discoloration I see in some of the lights?
  9. markb1
    markb1 Active Member
    San Diego, CA
    Perhaps there's an unreliable power supply component. LEDs aren't binary, though they are usually treated as such. Dimming is typically done by pulse width modulation (rapidly turning the LED on and off), but they will dim if the voltage drops, too.
  10. SabrToothSqrl
    PA
    Correct, the lower area, approx 1" wide isn't as white as the rest of the ring. It used to be.
  11. SabrToothSqrl
    PA
    Dying even more.
    And.. Lights out!
    also rust on the turn signal. Ugh.
  12. Johan
    Drammen, Norway
    Guy like I said you have to be smooth about inserting that thick cable in that tight hole. You have to gentle and kind if wiggle it in.
  13. SabrToothSqrl
    PA
    So many jokes... So little time.
  14. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    I've had two replaced as well.... Last one for the exact picture above.
    Thankfully, SC is 15 minutes and they are very accommodating ....
  15. Zextraterrestrial
    Humboldt/Los Altos
    they told me it would be an hour...after it took them an hour to change my visors. cant sit around all day in a SVC
  16. CHG-ON
    CHG-ON Still in love after all these miles
    Santa Cruz Mountains, USA
    I always wait for the light and make sure that I insert perfectly straight and all the way. I also keep both the plug and receptacle very clean. Have not had a problem yet. But I am always inside when charging, so it's easy to keep clean.
    Yes.. Too many jokes and no time. But I would not use any type of lube as it will collect dirt and grit and make things worse. Dry is best...in this case!!!
  17. SabrToothSqrl
    PA
    Red now...
    Now it looks like it's bleeding...
  18. islandbayy
    islandbayy Active Member
    Greendale, Wisconsin
    I disagree. I've found that once you've located the hole, line up the thick cable just right, and give a gentle but firm, even, push. It should slide in smooth and easily if lined up correctly.
  19. tom66
    tom66 Member
    United Kingdom
    The number of premature LED failures I have seen... LEDs can be reliable, but it is difficult to get reliability AND low cost AND high brightness. It's a case of pick any two. I have replaced 10x GU10 LED bulbs in the past year - these are the things that fit into kitchen lights etc. They all fail in the same way, one LED goes out and the whole bulb goes out. Back to halogen for me. These were quality brand bulbs too.
    LEDs last a long time (40,000 hours to half brightness), but only if they don't fail early. And too many of them are failing early.
  20. LetsGoFast
    LetsGoFast Active Member
    Virginia
    The multi-color version actually looks pretty cool.
