Billbrown1982
TM3 LR 2021 | Red | FSD
Its progress in the right direction, eventually I might be able to cancel my Tessie subscription although I think that might be a ways off.
it'll work if you just type it in, don't try to clear what's there already or paste it in. e.g. if your rate is $0.12 just type in "0.12" or ".12" or "12"Okay this is VERY frustrating, because I'm trying to set my charge rates for the Peak, Mid Peak and Off Peak times, and when I tap the fields they Autocomplete to $CA0.00. I go "Okay, I'll just clear the field and fill it with my rate...."
The for autofills every time you try and backspace on it. Even copying and the whole value doesn't work. The field just CONSTANTLY autocompletes to 0.00 with NO way of changing it.
Anybody find a way to work around this or have a word on when this will be patched. This seems like a MASSIVE oversight from QA. You literally CANNOT type in your charge rate because they felt the need to autocorrect as you type. I can't even set a fixed rate due to the same issue, so right now these stats are USELESS to me because it shows zero across the board.
No amount of typing works. You NEED to focus on the field in order to type, and doing so puts the cursor at the very end. Typing anything with the field just saying $CA0.00 doesn't add or change any digits. I'm willing to bet Tesla's autocomplete is borked for anybody that uses currency that isn't US due to the prefix on the field.it'll work if you just type it in, don't try to clear what's there already or paste it in. e.g. if your rate is $0.12 just type in "0.12" or ".12" or "12"
I even went and deleted the other half's phone key and drivers profile and checked the home location was correct. Still not there, at least I know i'm not the only one that it's not working for.Definitely not available for my Mobile yet.
No update available and previous update was 7th jan
Adopado.Just to answer my own question:
For the app to know that you have charged at your home location your home location has to be accurately registered by the car. We are out in the sticks and our actual address location and postcode for "Home" turns out to be a distance from where the car actually sits! You have to go through a few hoops to get the car to register a home location (normal car parked home location) that isn't a straightforward address. Anyway, I'm hoping that future charges will now not just show as "other" but will use my home charging prices.
Did you name your favourite "home" and then see a difference in behaviour?I seem to recall the solution was to be parked at home and set it as a Favourite called Home.
What were you getting? I’ve just tried and get 297. Same car. 2 years oldView attachment 764356I have noticed that my charge limit has recently increased (M3P)
1 year old now. Was getting 310 / 312. Worst was when brand new 305. so 317 very welcomeWhat were you getting? I’ve just tried and get 297. Same car. 2 years old
Most odd. What SW are you on and did it change after upgrading1 year old now. Was getting 310 / 312. Worst was when brand new 305. so 317 very welcome
No, that shouldn't be necessary:
facepalm ...I'm confused.. you've set your "Peak" time to the period when Octopus Go is active? And "Off Peak" when it isn't? Isn't that the reverse of the meaning of peak and off peak?
Strange that it coped with my swapped peak and off peak in 2 periods but wants to split the corrected periods into 3 when the peak goes past midnight. I just changed mine and it went to the 3 periods without me selecting the extra period manually! Oddly my numbers had shown the correct pricing before I changed them to what is the correct way round but I'm convinced my peak and off peak choices were initially correct so there might even have been some change in the background in how it works ... well that's my story! (I suppose I could have just changed the charging rate of Peak to my Off Peak and vice versa as it's just a label.)I'm confused.. you've set your "Peak" time to the period when Octopus Go is active? And "Off Peak" when it isn't? Isn't that the reverse of the meaning of peak and off peak?
Yes, the coarse rounding up and down means I can put 10kWh into the battery at cheap rate or peak rate and it's still a pound! I don't know if the system does record the charges in more detail and becomes nearer to reality after a number of charges ...Anyone got their heads round the fuel saving figures
i’ve used 103kWh for £6 showing a net saving of £51 on petrol
i assume they use 4miles per kWh and something like 50mpg at £1.40/litre
that sort of works out apart from being mostly short journeys at nowhere near 4miles/kWh
the individual charge costs must be from Poundland. Every home charge irrespective of size is a quid
2021.44.30.11 & im fairly sure it did.Most odd. What SW are you on and did it change after upgrading
I set the official Home setting to my post code. This is 200mm or so from where I live.Did you name your favourite "home" and then see a difference in behaviour?
I don't have a problem. Mine works and shows my car in the correct place. I don't set my "Home" to my postcode ... I set it to the new favourite I created.I set the official Home setting to my post code. This is 200mm or so from where I live.
Sitting in the car at home I then added a favourite called Home.
So if I tell the SatNav to take me home it 'stops' well short of the property but there is a pointer on the map where the property is.
When i'm charging at home I now have a few blue lines in the stats showing that as opposed to all the grey lines I have fo the first part of the 31 days.
Let me know if it works for you.
Thanks.
