Buzzliteyear
Did that just after buying the car, tried disabling it and then turning back on.Have you enabled data sharing with Tesla? That might do the trick. This has to be done in the car menu somewhere.
May be the beta is the problem, why don’t you go back to iOS15.3 public version instead of the iOS15.4 beta and then check. We all know that some apps do not work very well in iOS beta versions!Which version of IOS is your phone running?
I'm on the latest beta 15.4 and the local network setting is under privacy, which doesn't show the Tesla app
Note: To access this feature, the vehicle owner needs a Tesla App version 4.5.1 or higher and the vehicle software version 2021.44.25 or higher.Ladestatistiken verstehen | Tesla-Support Deutschland
Ladestatistiken in der Tesla App helfen Ihnen, das Ladeverhalten Ihres Fahrzeugs zu verstehen und wie es sich auf Ihre Gesamtkosten und Einsparungen durch den Besitz eines Tesla-Fahrzeugs bezieht.www.tesla.com
Software versions and car all look ok ... unexplained I'm afraid. Some others having an issue too.I am using the 4.5.1 app version installed on my IOS device and running 2021.44.30.11 on my tesla model 3 SRP 2021, but I don't see "Charge stats" even though based on the following statement I should:
any clue why ?
Not sure whether it is US specific as I don’t have those details in 4.5.1At the bottom if you click on view details in version 4.5 1 it will now give you your cars build details and also your warranty info.
Regarding Warranty information, it doesn't indicate the extended warranty info (as it is specified in your records by Tesla).At the bottom if you click on view details in version 4.5 1 it will now give you your cars build details and also your warranty info.
Ok, another one missing in lease cars then!Works in the UK here.. gives the warrany expiry details for all the various bits.
Do the full reset, if not, delete the app and reinstall, do the reset for car first and then reset the phone. If nothing works raise a service requestI'm at a loss;
iOS 15.3
app version 4.5.1 build 864
Software version 2021.44.30.12
Still not showing.
Its worth adding, this is not a least or anything, I purchased the car. Additionally, I don't have any home charging solution, wondering if that makes a difference but can't see how or why and I've only done around 700 miles, maybe not enough yet for this feature?
Keep us updated on this.I have emailed support and waiting for a reply.
