I am signed up for off-peak program with my electirc company.
Issue #1: Charging is scheduled for 11:30 PM, yet after I come home from work and plug in the charger (Tesla Wall Connector), it would start running for no apparent reason - you can tell by the green light moving down on the charger, and the electrical meter is spinning. At the same time, the screen still shows "Charging will start at 11:30 PM". You can override it by pressing the button on the handle of the charger, and that would stop the charger, but that is an inconvenience. This is happening during the highest rate which is 10x the normal rate!
Issue #2: When I turn on climate control in the morning to heat up the car (again, this happens during the hightest rate window), the wall charger starts going. I want the car to use the battery during that time and not the wall charger, but the only way to do that is to go to a cold garage and unplug the charger before starting warming up the car.
As a result, I paid more for on-peak use than I did for off-peak use - ouch, baby, very ouch! Dear Tesla Engineers, if you are reading this, Model 3 desperately needs an option to suppress charger use outside of charging window.
