Charging a Model S In the Wild
Discussion in 'Model S: Battery & Charging' started by Todd Burch, Jun 13, 2012.
  1. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    #61 Lloyd, Jun 23, 2012
    I noiticed from some of the photos from the factory today that the Clipper Creek TS-70's had been retrofitted with the new Tesla plug for the Model S! For those that have the Clipper Creek EVSE you should be able to buy just the cable and connector and charge at 70 amps. Not quite as fast as the 80 amps that is available from the new HPWC, but fast enough for me, and a savings from purchasing the new HPWC. Just thought I would throw that out for people to think about.
  2. dsm363
    dsm363 Roadster + Sig Model S
    Nevada
    70A is definitely fast enough. I think the new HPWC tops out at 80A but still really fast.
  3. Teo_atawki
    Teo_atawki Sig S res #703
    Any word on an adapter to connect an S to a Roadster HPC?
  4. hcsharp
    hcsharp Active Member
    Vermont
    Maybe the TS-70. I don't think you'll be able to put a Model S connector on the end of the HPC that was made for the Roadster. TS-70 can handle the proximity signal but I don't think the HPC can. I'm looking forward to finding out!
  5. Lloyd
    San Luis Obispo, CA
    #65 Lloyd, Jun 25, 2012
    Taken yesterday, These same EVSE's had roadster connectors on them at the Factory event.
  6. Lloyd
    San Luis Obispo, CA
    better photo
  7. roblab
    roblab Active Member
    Angwin (Napa Valley) CA
    Several of us have included that accessory in our final order, and they are working on it. I suspect it will be available July or August, but I don't know. The word is that they are "working on it". Along with a million other things.
  8. Teo_atawki
    I was asking because I have been looking forward to stopping at the burgerville in Centralia where there is a Roadster HPC for a combination car/driver recharge since I reserved my car.
  9. ChadS
    ChadS Last tank of gas: March 2009. EV miles: 254,000
    Redmond, WA
    Heh. I am sitting in my car, charging at Burgerville as I read this.
    I've talked to several employees, and they all insist the converter will be available--although none of them knew any details.
  10. FalconNinetyD
    FalconNinetyD Active Member
    Likewise, it'd be nice to have one for the San Diego to Las Vegas trip (300 miles), using the Tesla charger in Barstow.
  11. Kipernicus
    Kipernicus Model S Res#P1440
    Belmont, CA
    So it's not as simple as converting the roadster HPC to J1772 (as I understand the Rabobank ones have been) and then using the model S J1772 adapter?
  12. Lloyd
    San Luis Obispo, CA
    I believe that is available also if you want to use the converter. I would prefer to use the s connector directly.
  13. AndyM
    AndyM Member
    Sherwood, OR, USA
    The pics make it appear that the UMC is needed to use a J1772 source. I would expect the HPC to connect directly with an adapter, though... since it's all Tesla.
  14. hcsharp
    Vermont
    I don't think that's the same machine as the Roadster HPC. I could be wrong. The Roadster HPC had no way of handling the proximity signal. J1772 requires that. It's easy to put a Roadster connector on a machine made for J1772 but not the other way around.
  15. Lloyd
    San Luis Obispo, CA
  16. donauker
    donauker Member
    The proximity signal requires no circuitry in the EVSE. It is fully implemented with the switch and 2 resistors in the J1772 connector itself.
    http://en.wikipedia.org/wiki/SAE_J1772
