For your first few trips to a super charger sure aim to get there with 20% while you understand the process and the range estimates.
Once you get comfortable with this you can push your target arrival to a lower %.
If you want to minimize time at chargers you really want to aim to arrive closer to a 5% state of charge. The MY charges super fast up to 250kw/h from 5%-30% but then starts charging slower. So ideally you want to always utilize the time charging at that very fast 5-30% area. You also want to depart with less charge.
Also you want to ideally target 250kwh v3 superchargers and less stops at 150kwh v2 or older chargers.
I usually aim to arrive as I said at about 5%. But I plan that for cruising very fast maybe 80mph so probably speeding 5mph or so. Keep an eye on your range as you complete that leg of the trip. If you get into trouble where your estimated arrival creeps to 0% then slow down. EV are much more efficient at slower speeds. If you got into a severe range issue you could slow down to 50mph and you'll probably be able to go 50% farther.
I really enjoy doing road trips in my Tesla. If you can work on eventually doing some of these strategies to arrive closer to 5% I've seen where I cut about half the time off my charging stops.
