charging rate set at 30 amp but switches back to 48 and blows the circuit breaker????
What do we need to do to keep the charge setting at 30 Amps???
Exactly. The wall connector is J1772 behind the scenes. For J1772, the EVSE (the brick or station on the wall) via pilot signal duty cycle (Basics of SAE J1772) tells the connected car, this is how much you can draw at max. The assumption is that the EVSE is of the proper size/max output for the circuit it's attached (some cannot be configured) to or configured for that.Commission whatever EVSE (wall connector unit) you are using to not provide more than 30amps. Never (ever) depend on the CAR to keep that setting.
No. It depends on how you have it configured. See page 5 of https://www.tesla.com/sites/default...ng/Gen3_WallConnector_Installation_Manual.pdf. Previous gens are also configuring either via a dial or DIP switches.Wall connector needs a 60 amp breaker.
Sorry to revive this thread. I have a similar situation
- TM3 Extended
- Tasler Mobile Charger with 14-30 plug on a 30amps dryer line
- 30amp breaker
- did not manually set current limit on screen on phone app
The initial draw says on the phone app is 24amps. But, the breaker tripped in two separate instances, and each time the phone app said the last current draw was 48amps. It makes sense that the breakers tripped, but why would Tasler Charger with 14-30 plug even attempt to draw more than 24/30 amps after a while?
Too lazy to get into the car and limit the draw to 25amps. maybe that is the only sure way to limit the draw?
You are not interpreting this information incorrectly. A UMC with a 14-30 adapter will never draw more than 24 amps. Something else is tripping your breaker.But, the breaker tripped in two separate instances, and each time the phone app said the last current draw was 48amps.
