Yes, I've touched base with them on other issues as well. The usage is reversed (as well as the implementation). They were traveling in Supercharger-bereft lands. The car needed a charge more than the trailer. I'm picturing a situation where I have excess capacity in the vehicle, and not enough in the trailer. There are plenty of places in California that would qualify.Those folks who traveled across Canada in their X and a trailer did the opposite. Figured out a way to charge their X from the batteries in their trailer. They might have some suggestions. fortytwo is their name in these forums.
Heh. Yeah, I just don't like RV campgrounds in general. I want to be camping, not parking in a parking lot. Plus, many national parks and all of our local beach campgrounds don't have hookups. I'll still pay $50/night but I don't get hookups, so I'll need something to stretch the couple of days we'll be there.So where are the people who always say "Why are you so cheap? If you can afford a $150K car, you can pay for an RV campground"? I know they are around here somewhere...![]()
I believe that the 11.8-12.8v you're seeing is enough to "trickle to the trailer", but it's more a question of the amps that will be delivered, the wiring sizing, length to the battery etc., things you've already mentioned so you're obviously aware.OK, I've received the trailer and was finally able to test. Results:
Car "off" meaning key not in proximity: 11.8VDC-12.8VDC (fluctuating slowly)
Car in Neutral with Parking Brake engaged: 13.8VDC constant
Car in gear: I couldn't test without killing myself. I was alone.
Any idea why I'd be getting the first result? Is that going to be enough to trickle to the trailer? Clearly the second option is quite enough. I forget how long the car stays "alive" when one does this. Input on that?
This may not be my end game, but it's a solid workaround for anyone with an X in a pinch.
The 11.8V-12.8V is what I would expect to see from just the accessory battery. The lower end being either sag from the battery under load or a mostly discharged battery.OK, I've received the trailer and was finally able to test. Results:
I believe it is true that the 12V battery is recharged by the car (it has to or the 12V battery would have a very short lifespan in a Tesla) but not sure if that recharging happens when the car is in the "off" condition.If "off" is just the 12V accessory battery you're going to discharge it unless the car constantly monitors the accessory battery and turns on the DC/DC converter even when off.
Okay thanks. So it appears that one could charge a 12V trailer battery while towing with an X. Which could be helpful for many people.if the purpose is to charge the trailer battery when the car is off it's not going to work. 12V won't cut it. The voltage needs to be higher to charge a deep cycle agm battery (14.5'ish for charging, 13.8'ish for float).
Certainly running A/C via the inverter or other 110v systems through the inverter could cause that draw. But I'd be surprised if the wiring of the harness and the fuse is capable of handling the required current.A note - leaving the 7-pin adapter connected to the car while the car is parked/off and the trailer has no shore power will result in a significant drop in range. How significant? On the order of 30-40 miles overnight!
I thought I noticed this on my first boondocking trip with the camper, but then second guessed my memory. However, on this recent trip I have confirmed it. I suggest anyone with a trailer disconnect the 7-pin while camped overnight. It's far too lossy to be worthwhile.
I had similar thoughts. Perhaps the car is wasting energy ?Certainly running A/C via the inverter or other 110v systems through the inverter could cause that draw. But I'd be surprised if the wiring of the harness and the fuse is capable of handling the required current.
30-40 miles at 550Wh/mi (with trailer) would be ~15-20 kWh. Using the lower end, over 10 hours that draw is 1.5kW each hour. So a 1500 watt use in an hour would require an ~100 amp current flow at 14v through the harness. That would require roughly 6-10 ga wiring. Quick search seems to suggest that most of the 7-way SAE connectors use smaller wire and are fused at 15amps DC.
Based on my calculations the fuse should blow way before the wiring fried.
One really interesting experience we had on our last trip was waking up in the morning to a camp host telling us that our car had its lights on all night. We realized that the key fob for the car was in our clothes in the trailer within range of the vehicle (they were not unhooked), and that the vehicle did not shut down during the night. After that incident, we made a place to put the fobs in the bathroom so it was far enough away from the vehicle to allow it to "sleep". JimI'm not sure exactly why this occurs, and agree that it seems like an awful lot. One explanation is that the car may not sleep, so vampire drain is exacerbated.
We are sensitive to this as well, mostly because my wife is worried that someone might "drive away with us."One really interesting experience we had on our last trip was waking up in the morning to a camp host telling us that our car had its lights on all night. We realized that the key fob for the car was in our clothes in the trailer within range of the vehicle (they were not unhooked), and that the vehicle did not shut down during the night. After that incident, we made a place to put the fobs in the bathroom so it was far enough away from the vehicle to allow it to "sleep". Jim
Interesting. I'll do a driveway test next week at some point and report back. I was going to say that he was probably hooked up to shore power, but it doesn't appear that was the case.Ran across this in the Edmond's Model X towing article (a reply by author in the comment section):
"I do know that I left the rig parked for two days while I attended to my Ram duties. The car was off, the trailer lights were off, and I did not unplug the 7-pin connector while it sat for 48 hours. No loss of range doing that." [emphasis added]
Towing a Teardrop Trailer to Flagstaff - 2016 Tesla Model X Long-Term Road Test
