The nominal diameter of a 245 45 19 is 27.7".
Nominal diameter of a 245 35 21 is 27.8".
Nominal diameter of a 155 80 18 is 27.8".
So the compact spare I have is exactly the same nominal diameter as a 21 OEM wheel, which is 1/10" bigger than a 19" wheel.
I don't see how running a wheel 1/10th of an inch larger in diameter could cause any issues with the driveline--like I said, the reason you have a differential is to allow one tire to turn faster than the other, while going around corners.
With a big enough size difference and limited slip diff you might have a problem. But this is not a big size difference and there is no LSD.
But if (and this is a big if) there were any negative effects from the small size difference, those effects should be the same whether you are running a 19" OEM wheel on a car with 21s, a 21" OEM wheel on a car with 19s, or a 155 80 18 space saver on a car with 19s.
Of course, on a car with 21s the 155 80 18 space saver is the same size.
