Daniel in SD
(supervised)
You need to correct for this in your model. It looks like there have been huge jumps the last three Tuesdays.It seems that there may be more reporting lags on Sundays. I
Seriously??? Contagion had a fictitious virus that killed large numbers of young, healthy people. This is nothing of the sort. Again, I have to ask: where were you in October 2019? Were you calling for a national shutdown because the upcoming flu season was going to cause:
1. 39 to 56 million cases
2. 18 to 26 million doctors visits
3. 410,000 to 740,000 hospitalizations
4. 24,000 to 62,000 deaths
Preliminary In-Season 2019-2020 Flu Burden Estimates
This happens every year in the US. The main fatalities every year are the same for Covid-19 and the flu. Where were your calls for government to enforce social distancing, wear masks, etc.??? That would have worked just as well for the flu as it does for Covid-19. You could have saved up to 62 thousand people had you been vigilant.
I keep seeing this comparison to the flu . . . but does anyone realize those flu deaths are with ZERO social distancing?
SARS-CoV2 is on track in 2-3 months eclipse total yearly influenza deaths, and that is WITH social distancing.
Let's all let that sink in for a few minutes, OK?
Well, have *you* been shouting every October for a national shutdown over the flu? It happens every year. Tens of thousands die. A shutdown would limit those deaths. Don't spew the usual "vaccine", etc talk because you, of all people, know it's going to happen.It appears you have been in a coma for the past three weeks. You've already lost this argument. Move on to the next form of minimization and BS. This form is out of date. I am confident that you can improve your game and with practice come up with something new however.
Deaths today were again a little lower than expected, 22,105 down from projected 20,577. This again reduces the projected ultimates to 71k. It also suggests that April 10 could stand as the peak.
It seems that there may be more reporting lags on Sundays. If counts stay below expectation, we'll continue to see the end come sooner. But equally true, if the pace picks up, we expectations could get much worse. The value of a tracking model like this is that it helps us see if we are making progress bending the curve.
OK, so, tens of thousands of preventable deaths a year are A-OK with you? Hey, I told them to get vaccinated in the Fall but they didn't so it's OK they died from the flu. Is that what you're saying?FACEPALM. Since it appears refresher courses are needed, I'm quoting myself:
Great, that's what I want to hear from you. I respect that.... Yes, I'm perfectly fine with the deaths we see each year given the above circumstances for Influenza. ...
We have over-ventilated the nation. If you get sick you don't want to go on one, most never recover; they damage the lungs. Cause more damage than good usually. Patients need oxygen not high pressure.
so much for telling states to get their own ventilators...
I’m no doctor but my understanding is that you start on oxygen, then when your blood oxygen drops you go on a non invasive ventilator and then when your blood oxygen gets low again you get intubated. I think you need oxygen in your blood to be alive. Again, I’m not a doctor.We have over-ventilated the nation. If you get sick you don't want to go on one, most never recover; they damage the lungs. Cause more damage than good usually. Patients need oxygen not high pressure.
I'm going off this guy. And based on him I should revise my statements. He's saying they need to revise the protocols of how to use the ventilators. They are using too much pressure.I’m no doctor but my understanding is that you start on oxygen, then when your blood oxygen drops you go on a non invasive ventilator and then when your blood oxygen gets low again you get intubated. I think you need oxygen in your blood to be alive. Again, I’m not a doctor.
i.e. Your sister's mother?
This was why/when Trump started taking COVID-19 seriously... when someone he knows actually fell victim. Before then, who cares...
Stanley Chera, New York real estate mogul and Trump friend, has died of coronavirus complications - CNN
BTW Garmin watches, good ones, can track not just resting heart rate but also blood oxygen levels and respiration rate. Being a dude that runs trail races for over 24 hours non stop I use the 945. Love it way more than the Apple Watch. If you have the means, and you do since we’re all TSLA rich, I highly suggest picking one up.
The watch is in part the reason I have a high degree of confidence I have antibodies in my system.
It looks like 81% of Americans have smartphones. Most homeless people seem to have smartphones around here. It's certainly enough to track down clusters if you're ever able to get the numbers down to a reasonable number.
That's probably less than 1% of the population of Germany right now.
If the Typhoid Mary had a smartphone it would be possible once she infected two unconnected people.
This is of course assuming that surface contamination is not a significant source of transmission.
I'm not saying any of this is likely to happen, just that I believe it would work. I think it's more likely than testing everyone in the country every two weeks.
