JRP3
Hyperactive Member
In harsh environments, such as boats, steel is rarely used, (other than commercial boats), but aluminum is often used. Draw your own conclusions.
I'm getting a Sig, so I'll have the tech package and theoretically won't need to "hold" the fob or press buttons on it.
Still, things in my pockets seem to to have a low survival rate... keys (still need them to open my house and office), ID badge, iPhone, and other random stuff all seem to age prematurely
/Mitch.
I presume they'll design the car with appropriate coatings, etc., to avoid putting dissimilar metals in contact.
This raises a question though. Is an aluminum car body actually better or worse for corrosion?
In theory, aluminum doesn't corrode as much because its oxide seals the metal, whereas iron oxide is a catalyst for corrosion.
On the other hand, there are other materials spread around on the road, namely salt and in some case salt alternatives. They could have an impact.
Some people I have talked to have claimed that aluminum cars corrode quickly, others say they don't corrode at all. I know only one person with an all-aluminum car, and he doesn't winter drive it. Is there anyone here who can put that question to rest?
Accessorize with a "key fob case" :smile:
A little bit of rubber cement would probably hold a worn out cover in place and still allow removal. Or duct tape :wink:
Maybe I can convice my fiance to get rid of DirecTV and then I can almost finance the 60kWh pack, and get some piece of mind for 4 years down the road when I would start having to worry about the 40kWh pack degrading and putting me into a position where I won't be able to drive 75mph to work and back.
You must be commuting during non-rush hour times if you're able to get up to 75 mph here in Atlanta.
You also spend a lot on gasoline.
I put 90k miles on my car in 5 years, with 1.5 of that living 2 miles from work.
Well it sounds like you need to go up to the 85 kWh so you can get 8 years - unlimited miles on the warranty. Of course you cannot put 90,000 miles on a Model S in 5 years if you tried. You just can't make 500 mile trips with the same ease.
Apparently a lot of men in the 35-54 bracket are likely to do it.I disagree,. You can easily put 90K on an S in 5 years.
