I have noticed for about a week or two that my P3D's acceleration is being restricted with the famous restriction dots (see image)
That's not the reason you're getting the dots with a low battery and colder weather.In the past week or so, I had a few dots on the right when the battery was low and I was driving as I usually do, and last week I had those dots reach nearly to the middle as the battery was already low when I got to work, then it sat in 40 degree weather for 8 hours and I had to get home. That story deserves its own topic.
But yes, Tesla is holding the P3D back. They can't have it being faster then the S100D Ludicrous, that's not good for corporate profits.
Wow I can't believe (actually I can based on my horrible customer service experiences) that the service guys didn't see an issue with your car. Are you doing mountain driving or is this mostly on the flat? That power usage is crazy. What's your average WH/Mile right now?
The reason that is not a possibility is because when it is too cold those dots appear before you start driving and as the car worms up they go away. Also a little snow flake icon is presented. In my case they come up only when the car is pushed but immediately after its pushed and they don't if driving normal. Also this didn't happen before under same weather conditions. I am also in CA where we don't have cold weather.Could it be that car is too cold due to the weather?
I have noticed this the last few days since we’ve had a cold front (in the 30’s F) blow through.
Admittedly, I don’t drive my car as hard as you.
But this has not been the case for me in the first month of owning it and I driving it super hard then too. In fact I duplicated the exact conditions and roads. So this is a new phenomenon either because of something broken or change in over the air software update. Also here where I live we still get 74 degree weather so temperature can't be an issue and I have not driven the car with low battery.In the past week or so, I had a few dots on the right when the battery was low and I was driving as I usually do, and last week I had those dots reach nearly to the middle as the battery was already low when I got to work, then it sat in 40 degree weather for 8 hours and I had to get home. That story deserves its own topic.
Its not cool soaked. I can drive the car normally for hours until it is categorically warmed up then the moment I push it, I get the dots within 2 minutes. This is a head soak indication. Tested in all temperature ranges available here in CA (54 to 80). It happens in all temps now and it didn't happen before last over the air update. Also I can't hear the fan as I would in the past when pushing the car.If they were holding it back for warranty reasons, they certainly wouldn’t be advertising it with the dots.
It’s likely cool soaked. It also looks like it’s 100%?
Mountain driving at obscene speeds but again its not something new. I have done it before with no problems. This just started happening.Wow I can't believe (actually I can based on my horrible customer service experiences) that the service guys didn't see an issue with your car. Are you doing mountain driving or is this mostly on the flat? That power usage is crazy. What's your average WH/Mile right now?
Unfortunately although Elon promised Track Mode for P3D-, he did not deliver.Do you have the option to turn on Track mode to see if it gets better? I wonder if this is like the Power Limiting thing Tesla did with the P90D's last year.
By accelerating hard at every opportunity. Then slowing down on the corners just enough not fly of the cliff then back to full acceleration. Basically there is no coast -- just braking or pedal to the floor. Also the P3D is a heavy power consumer even when driving like a snail. One day I tried really hard to get the rated Wh/mile and although I got close I found it was impossible to achieve. Maybe if you drive exactly 30 mph continuously or only downhill?How do you sustain over 900 wh/mile for multiple miles?
