It could also be that one of your components is still working but has an issue where its generating excess heat due to a high resistance connection, or failing but not failed component. If a service tech was looking at this issue remotely, its probably looking to them like you "Drive too hard" .
They may look at individual sensors and see if the temp setpoints are properly throttling you, but they have little to go on when comparing you to another user. Even among P3D drivers you drive hard. Harder than anyone I have heard of short of a full race track.
Imagine that for instance your DU is failing, and the failure mode is some component is producing 5-10x the heat it should be. During normal driving the cooling system keeps up just fine, but the issue becomes obvious during race conditions. How is the tech to know the difference between your car when the DU temp setpoint is hit in 2 minutes, causing throttling, vs the average person who hits that high temp setpoint in 10-20 minutes? If they compare power graphs, yours likely looks higher than most. Conclusion, he's driving hard and is limiting power sooner than the average driver.
