Thx a lot! I think I’ve got it now. I get the annual net metering (with time of use $) process I believe.As my tag line states, I have a generator, solar, and batteries.
Under NEM2, there is no wholesale info. At true up, the cost I get back is in the wholesale
yes, export onto the grid is outflow excess.
Does not matter where the 90kwh comes from, solar, batteries, generator, etc. If the meter sees 90hwh coming from you past meter back to meter to grid, you get 90kwh credit.
Now for the month, there is on the black and white bill, the total month usage from grid, and month how much you sent back. They net this out per month. At 12 months they net it all out and either you pay, or get pennies back on the dollar, like I do.
so if you pulled 100kwh from the grid, and sent back 90kwh, your net would be -10kwh. But its not the amount, it is the cost of energy
at the time you send and pull that is what is the bottom net dollar amount on the bill, positive or negative. I have large negatives on my net monthly bill. This time of the year I use these credits from the summer when pump huge amounts to PG.
But it was this monthly export cap I was struggling to understand. As I understand from your last post…PGE can/does measure the outflow only out of your meter, and this is compared against the monthly PVWatts generation limit they have for your based on number of panels, orientation, etc, etc. so on a monthly basis you cannot exceed this amount.
So it’s kinda two things in parallel you have to manage.
It seems like in this case using a ESS with grid charging for TOU arbitrage could help more in the winter months when you don’t have a lot of sun. But that said, you may not even need to do that (in your case it sounds like you have so much summer credits built up that you don’t need to bother with TOU arbitrage).
Btw, do you or anyone else have a redacted (not looking for anyone’s personally identifiable info) version of this “black and white” bill?
