Daniel in SD
(supervised)
I don't think tires could explain the inconsistency.Issue could also be the tires (especially the MXM4s). A better set of tires can significantly reduce stopping distance.
How many owners take their cars up to 60mph and then do a full emergency stop?
CR is doing this so you don’t have to and these results are not good.
They also confirmed this with a second Model 3 and with the staff at Car and Driver who got similar results.
The one saving grace on these terrible results is that Tesla can likely improve or fix the performance with OTA updates unless the problem is in the braking hardware.
I agree with this. Too many drink the Tesla Kool-Aide and think they have no flaws. Do I love my model 3? ABSOLUTELY. Is it perfect? NO. Is anything perfect? NO. I trust consumer reports. They do standard testing for all cars (to weed out bias) and they use their money from subscribers to buy cars (so they can remain independent. The good news is this issue is fixable as stated via OTA. I get you probably won't ever slam on your brakes at 60 mph but if there is an issue I am glad someone noticed it and can get it corrected from my garage (which is a HUGE benefit of Tesla).
Seems like Tesla needs to contact Brembo about the brake pad formulation they're supplying...
Q: Does a choice of tires affect the Tesla Model 3's emergency stopping distance? A: Our car executed a panic stop from 60 mph in 133 feet with the standard 18-inch wheels and tires, and that dropped to 128 feet after we installed the optional 19-inch configuration. A small difference but a clear improvement.
Given the small difference between wet and dry, a possible explanation could be that the ABS system is detecting wheel lock that's just not there and is being too conservative in dry conditions. If it were very close to an edge case, you'd get a system that sometimes produced 130-ish ft results and sometimes 150-ish foot results not correlated to actual conditions. That seems to be close to what CR & Car and Driver are seeing. Motor Trend's 119 is a bit of an outlier.
Tesla could easily confirm that's what happened with logs. No need for them to fire back with "but it worked when we tested it"
Maybe? I sort of think ABS controllers are a bit of an embedded system at this point. Not sure how much they log. I'm sure Tesla can log what sort of force is currently applied to the brake pedal, but less convinced they can log ABS decision making.
That's with wider max performance tires on a lighter car. 128 feet is with all-season tires. The performance model should have better braking distances.128 feet is still too much. It should be under 110 Feet. Last M3 was 104 feet, current M3 is 99 feet.
When you slam on the brakes the ABS should be modulating the brake pressure all the way down to 0mph. Stickier tires just make the stopping distance shorter, they don't make the ABS modulate less.If the ABS is being ultra conservative, tires with poor grip will cause the ABS to engage more often in hard stops. Depending how often the ABS engages would cause inconsistent stopping distances.
