hugh_jassol
The Navak doesn't/can't allow a charging pad to pull a higher amperage than plugging the charging pad straight into the USB. The only trick it does is allow more power through the charging output vs. other Y-splitters
@Kevy Baby covered this question in a excellent wayI also think that you need one splitter only.
Right... that's what I meant... when you use the "other" Y-splitters, it makes the charging side "dumb" by cutting off the data lines, so it can't charge at more than 5W
