henderrj
Will the wall connector need a specific outlet to connect to and a certain amp breaker?. Is this something that is just plug in and go or do I need someone certified to install it?.
The simplest plug-in play is to have a nema 1450 plug put in. That's the same thing that RVs use. Then you can use the mobile adapter that came with your car, adding a 240 volt adapter, and charge quite simply. Although the wall adapter can be outfitted with a 1450 connector, it is usually directly connected to the circuit breaker box.
