Hopefully I answered most questions in the video...let me know if you have anymore.
I bought this $36 Mirror Mount off Amazon since Blendmount doesn't have one that works with the Model 3 yet, but the fit is not very good, the part clipping onto the neck of the mirror is blocking the mirror from tilting up fully. It works okay if I adjust the seat all the way down but I like to seat higher up. I will wait for Blendmount to come out with a compatible mount. The Blendmount on my Wife's Model X has been rock solid and fits perfectly, well worth the extra cost ($129).
You basically summarized where I'm at. I have a 750S 2CH that I am going to install and I've been wrestling with how to power it. I want to ultimately have it constantly powered but I'm waiting to see how things shake out for a 12V constant source that is proven to not produce issues/errors.I have a blackvue 750s that I bought well before my Model 3.
I've been waiting for basically a "final" solution on how people are setting these up.
It looks like there are 2 solutions, one to connect to the 12V (with possibly getting an error from the car)
The other as getting one of the external batteries made for dashcams (expensive).
My question now is, if i get the cameras installed without having a solution for powering when the car is off, will it be easy to then add that solution when I'm comfortable with it, or would that be a mess to do?
Is connecting to the 12v a drastically different setup then connecting to the cigarette lighter via Cellink Neo or other?
No, I'm terrible at these type things.Are you comfortable wiring it up yourself?
My hardwire set up is very straightforward with nothing exposed besides the switch under the glovebox. All the extra soldering work I did was to add a bunch of quick disconnect points for easy removability/maintenance/modularity. Didn’t need to make any permanent or obvious changes to the car . And of course since that’s the DIY solution right now you can customize it to your needs.
If I ultimately need to install the battery, I figure I would stick it under the passenger seat and get creative with the wiring. But it shouldn’t be too difficult.
I kind of mind at the moment paying $300 for what's essentially a 6,000 mah battery.
Awesome - is the battery life any longer with this model?Just swapped the 750S on my 3 with the new 900S
I plan on doing this in the future too! Havent watched your video yet, but can you slip out the old camera and plug-and-play the new one? Any fit issues with the 750s housing in the swap?
I don't mind paying for the install, I kind of mind at the moment paying $300 for what's essentially a 6,000 mah battery.
Agreed I got the blackvue 750s dual cameras last week when there was a 15% eBay coupon for a total of $248 for brand new cameras. I feel like the battery pack is way too expensive at nearly $300. I feel like I should have just gotten a cheaper camera and plugged into the cigarette lighter. Wouldn't get parking mode but would get the job done while driving and save a ton of money. It's a wonderful car but I don't think I could justify 1k+ for a dash cam setup after install and all.
